24-Mar-2016, 04:48 PM
Hello,
I have written this exact post on the cleanflight flashing tutorial on Oscars blog but I thought posting it here might be easier.
I have been expericencing some troubles trying to flash my DYS SN20A ESC's with the latest firmware. From factory they come shipped with BLHeli 14.0 so naturally i wanted to update them to 14.4. I am using cleanflight to do so and i have gotten the ESC's to connect. I could read the settings and see that they were all on 14.0 and i could also see that one ESC was out of sync. As soon as i try to use the flash firmware feature I am met with an error. "Error writing to the flash", when clicking OK you get "Failed to write to Flash! ("Write failed" error)" and then finally "ESC#3: Flash FAILED. DYS_SN20A (Multi) BLHeli Rev: 14.4.
And now when you check the ESC status it says **FLASH*FAILED** instead of the version as if the current firmware now has been corrupted. To me it seems like quite an odd problem in that i can read the chip but not write to it. I was hoping that you or someone else could maybe help me out.
Im looking forward to reading the answers.
Thanks in advance.
- Oliver
Thanks in advance.
- Oliver
