02-Aug-2018, 12:43 PM (This post was last modified: 04-Aug-2018, 01:10 PM by Blackhole.fpv.)
[BlackHole FPV Sharing] Build iFlight Dragon Teeth v2 FPV quad
iFlight Dragon Teeth V2 frame
Front and rear Aluminum support, top mounted battery, 4mm carbon fiber plate Unibody”main frame with 25mm height Aluminum support. It 's very durable design.
Spec:
HGLRC Tower: F4 FC + 60A 4in1 ESC + VTX
HGLRC Motor : Flame 2306 2450kV motor
Gemfan props: Flash 5149
Foxeer Camera: Predator
Foxeer Antenna: Lollipop
PID Sharing
Let's see the finished product~~~
Top Mounted battery, Low CG. The"low-rider" style top-plate. This lowered mount gets the battery closer to the center of gravity for this machine
Integrated HD Camera mounting plate, larger space on the top for larger battery size, e.g 4S 1800mAh size LiPo battery
Battery, we’ve chosen GNB new 1500mAh 130C, you will feel the thrust different with the others
Gemfan new Flash 5149 props, durable and fast response. Included some lovely stickers in the package, i love it
Purple Gemfan props with purple HGLRC motors, PERFECT MATCH!
HGLRC FLAME 2306 2450kV brushless motor, They are built from high-quality aluminum alloy which is produced from the latest CNC milling machines.
Electronic parts, we've chosen HGLRC new Tower: TITAN plus F406+GTX585, it included F4 Flight controller + 60A 4in1 esc + VTX, 3 layers tower.
Foxeer Predatror V1 FPV camera, but V2 is released in this stage.
Foxeer Lollipop Vtx antenna, but V2 is released in this stage as well.
Parts list:
iFlight Dragon Teeth v2 frame
HGLRC TITAN plus F460 +GTX585 Tower, FC+PCB+ESC+Vtx tower
HGLRC Flame 2306 2450kV brushless motors
Foxeer Perdator V1 FPV camera with 1.8mm lens
Gemfan Flash 5149-3 props
GNB 1500/1800 4s 130C Lipo
Let’s show the frame:
iFlight Dragon Teeth V2 frame, aluminum structure on the front and rear, this frame corners the market for providing the most protection and versatility in mounting your cameras and it’s extremely durable.
Many space inside the body, easy to build for a newbie.
All frame parts
3 layers tower, FC+4in1 ESC+Vtx, very easy to install for a electronic dummy.
Let’s start to build:
Measure how long you want the XT60 pigtail to be and solder it to FC with Capacitor (this will reduce some of the noise from ESC and motors, which could affect your Gyro sensor and FPV video) then install to the frame with 4 long screws (around 25mm length)
We decided to use heat shrink tube for motor wires and solder those wires to the botton of the FC, it looks tidy and protect the motor wires.
HGLRC TITAN Tower FC includes advanced F4 Omnibus Flight Controller with extremely powerful 60A 4 in 1 ESC. The advantage of TOWER FC is simpifly the assembly process, it just connect the FC to ESC.
4 independant anti vibation rubbers are included.
But there are some devices that you need to connect to FC, e.g. Vtx/LED/ beeper/ FPV camera/ Receiver.
If you want to change the vtx channel by build in betaflight OSD, you should connect Rx wire (from vtx) to point TX3 (from FC) , please use uart3 in betaflight.
HGLRC GTX585 Vtx, it integrated 2 x M3 holes then it can be attached to the FC properly.
FPV camera is super fit to the frame
The receiver is attached on the top plate by double-side tape
FINISHED!!!!!!
Honestly, it is a little heavy then the racing quads but it is suitable for freestyle
iFiglht Dragon Teeth v2 with his elder brother Dragon Teeth v1
Spec:
PID Sharing
Parts list:
All frame parts
FINISHED!!!!!!
