Threads: 125
Likes Given: 99
388 The ground next to the LED is not a common ground but likely connected to a PINIO. And it only connects to ground when activated. Most FC usually make some kind of marking to indicate that it is not a common ground. They do the same for Buzz, where there is usually a Buzz+ and Buzz-. So you can't connect your VTX to that ground pad and expect power.
Threads: 92
Likes Given: 0
27 The betafpv site shows vtx wired to pads pointed by red arrow.
Threads: 583
Likes Received: 8,948 in 6,622 posts
Likes Given: 1,425
786 This is BetaFPV product we are talking about here so why am I not surprised. The 5V pad denoted by the red arrow should work the same as the other 5V pads, so I guess there is either a fault on the board or general design flaw with that version of the FC and is probably a reason why there have now been 4 versions of that same FC.
