Betaflight rc_smooth_interval_ms question
Can anyone help me to get rc smoothing to work with betaflight 1.6.4?  I'm getting 2ms stepping in my rc_command, and its making my P and D values really wonky.  I've tried rc_smooth_interval_ms = 0,1,2,3 with no difference.  Is there something else that I need to do to get the rc_command to smooth out like it does in cleanflight?
You should upgrade to a newer betaflight, rc smoothing might not be an option on that version. if it is, it will be a cli command.
  Betaflight Github questions Rob Axel 6 181 13-Feb-2024, 11:40 AM
  betaflight config 10.10 RC2 issue Rob Axel 3 209 10-Feb-2024, 01:21 PM
  Help question on windows 11 roger74 4 342 15-Aug-2023, 11:51 AM
Last Post: roger74
  Betaflight Motor Test Results in SmokeStopper overvoltage LoganFPV 5 231 01-Aug-2023, 11:22 AM
  Help A question about range extenders... graywoulf 0 168 17-Jun-2023, 05:26 PM
Last Post: graywoulf
