15-Apr-2017, 01:06 PM
Hi,
I use a F3 brushed FC (http://www.banggood.com/Realacc-F3-V1_0-...21378.html) but have some problems after I changed the frame.
My last frame was broken during a crash so I replaced it with a new one. However, from now on I can't really control the throttle anymore. As soon as I arm and give a little bit of throttle, the motors spin up fast and get incrementally faster (so fast, the quad would lift up). When I give full throttle, it seems that I can still spin up the motors a little bit faster.
When I go to the motors tab, I can continously spin up and down the motors without problems.
ESC set to brushed, PWM set to 32000 and min/max command set to 1000/2000.
I also reflashed the firmware.
I flew it fine before, but know I can't get it to work right. Could it be, that the FC is somehow damaged (although I can control the motors fine in the motors tab)?
