Betaflight - motors spin up fast after arming
Hi,
I use a F3 brushed FC (http://www.banggood.com/Realacc-F3-V1_0-...21378.html) but have some problems after I changed the frame.
My last frame was broken during a crash so I replaced it with a new one. However, from now on I can't really control the throttle anymore. As soon as I arm and give a little bit of throttle, the motors spin up fast and get incrementally faster (so fast, the quad would lift up). When I give full throttle, it seems that I can still spin up the motors a little bit faster.
When I go to the motors tab, I can continously spin up and down the motors without problems.
ESC set to brushed, PWM set to 32000 and min/max command set to 1000/2000.
I also reflashed the firmware.
I flew it fine before, but know I can't get it to work right. Could it be, that the FC is somehow damaged (although I can control the motors fine in the motors tab)?
Can you check motor order? Use the motor tab in configurator:
4 2
3 1
It could be that your FC is mounted the wrong orientation...
If this is happening on the bench with no props on, this is expected behaviour as the flight controller is trying to fly the quad.
  Ordered the HDZERO mob6 with the eco camera and 28k motors Rob Axel 35 1,020 21-Apr-2024, 06:25 PM
Last Post: iFly4rotors
  1102 motors on a 65mm pusher? ph2t 12 244 20-Apr-2024, 03:30 AM
Last Post: brettbrandon
  Build 1106 motors on 4S for a 2" prop mstc 10 190 19-Apr-2024, 06:30 PM
Last Post: mstc
  Throttle curves on Betaflight? husafreak 7 236 26-Feb-2024, 04:39 PM
Last Post: drumgod
  Nice looking motors for a 3"er build skywanderer 3 176 17-Jan-2024, 11:00 PM
