01-Jun-2017, 11:06 AM
Betaflight FC users, what settings do you use for gyro sampling and looptime ?
I'm using DSHOT 600 ESCs.
Betaflight FC Gyro sampling and looptime |
01-Jun-2017, 11:06 AM Betaflight FC users, what settings do you use for gyro sampling and looptime ? I'm using DSHOT 600 ESCs. 01-Jun-2017, 11:10 AM Try to use 8K/8K that should give you the best performance supposedly But watch your CPU usage, i'd not go above 30-35% while on the bench. Turn off accelerometer if you fly only acro. 01-Jun-2017, 12:33 PM Should be fine even if you Cpu goes past 40 close to 50 on 8k/8k, but I doubt you will get that high. If your going to run a slower loop time then just run multi shot. Dshot is better with noise and you don't need to calibrate your ESCs other than that it doesn't feel any different. |
BetaFlight Connection Issues..... | Coleon | 17 | 520 | 02-Apr-2024, 12:26 PM Last Post: iFly4rotors | |
Betaflight 4.4.3 on Speedybee F4V4 | Ladu | 4 | 197 | 14-Mar-2024, 04:45 PM Last Post: Ladu | |
Betaflight Configurator little yellow tick marks | soky157 | 3 | 204 | 23-Jan-2024, 11:25 PM Last Post: soky157 | |
Flight controller not recognizing CRSF in betaflight | SenaFPV | 10 | 535 | 15-Jan-2024, 09:03 AM Last Post: SnowLeopardFPV | |
M10 GPS not showing in Betaflight | Fuzzi | 9 | 1,051 | 14-Jan-2024, 10:56 PM Last Post: Coleon |
