Betaflight
Hello,
I'm having trouble with betaflight: when I move the sticks on my taranis qx7 nothing moves on the receiver menu of betaflight. I've got an F405mk2 fc and xm+ receiver. I've tried many things such as softserial and soldering the sbus cable on the uninverted sbus pin of the receiver thinking that might be the problem. Still nothing.
That should be a relatively easy fix as I just had to get help yesterday for the same exact thing. Here is where you should start. There are also several more articles that are relevant to start using the forum. This one with the link should be enough to at least help get your problem solved Trust this is the best way for people to see what's going on. There just is so much info as I'm sure your realizing now to go through.
https://intofpv.com/t-help-us-help-you
ok, I'll create a new post
You don’t need to do that just continue with this one just post the diff all and you wiring pictures. If you have any questions about how to do something just ask. I’m a certified computer dummy, I’ve had several issues resolved here over the past year.
  Fettec G4 mixed with Betaflight 60 amp 6S esc mattyfleischfpv 0 204 16-Feb-2024, 03:19 PM
Last Post: mattyfleischfpv
  FC Hoe to restore UART'S in Ports tab betaflight.. whatever 4 1,877 05-Aug-2021, 11:27 PM
Last Post: whatever
  Betaflight no seeing battery voltage yammahoppy 12 13,674 09-Jan-2020, 08:19 PM
  Tutorial Learning Acro - How to Use Acro Trainer Mode in Betaflight 3.4 SnowLeopardFPV 0 14,418 19-Jul-2018, 03:44 PM
  Tutorial Adding Adressable RGB LEDs and Betaflight Setup Video Drone0fPrey 5 2,440 23-Jun-2018, 06:51 PM
Last Post: Drone0fPrey
