Threads: 20
Likes Received: 15 in 6 posts
Likes Given: 1
0 I have a Beecore from BG that my Taranis won't bind to because it needs D8 and I have the EU FW so only D16 is available.
All my other RXs are X series so this hasn't been a problem until the Beecore.
My question, can I have D8 and D16 on the Taranis and still have the EU FW, or do I need to flash the international version and all my X series RXs?
Threads: 30
Likes Received: 9 in 9 posts
Likes Given: 1
1 No, D8 is only available in international firmware, you will need to flash all your Rx's
Threads: 21
Likes Received: 6 in 6 posts
0 Just flash OpenTX with the EU option disabled onto your Taranis. No need to flash the internal XJT module.
D8 mode is on all versions of the XJT module available.
Threads: 4
Likes Received: 15 in 11 posts
Likes Given: 6
0 If i'm not mistaken the only way to have the D16 is to flash the non- EU software to the taranis.
i did it to my taranis and it was pretty simple so don't fear the process.
Not 100% sure but i think i also needed to flash the receivers to the non-Eu software .
This is even easier using the taranis itself.
Greatz
Maxke
Threads: 2
Likes Received: 8 in 4 posts
Likes Given: 1
0 D8 isn't selectable in latest openTX? Mine is like 2.16 and D8 could be selected and beecore binds to it
Threads: 18
Likes Received: 69 in 48 posts
Likes Given: 33
9 I have a EU Tarans with version 2.16 and i can still select D8 mode, for flying with my QX95
