Beecore Issue
Hey guys I just got my beecore today. I got it bound up. I got the flysky one. But something seems off. The minimum values showing in clean flight are all 1024 not the normal 1000. I also had to use the subtrim the channels allot to get it centered but still the minimum is all 1024 for all channels. When I tried to maiden it today it flipped out of control too. Is there anything I can do to fix this. Thanks. I haven't had this issue on any of my other quads
I know for the DSM version, the built in RX has a limited ranges which you need to inform betaflight about with RXRANGE command (the exact values will depend on your receiver) - but after getting the maximum range in betaflight write down the numbers, narrow the range just a hair (if you can get 1024-1700 - for example - use 1030-1694)
then run the following command in CLI:
rxrange 0 1030 1694
rxrange 1 1030 1694
rxrange 2 1030 1694
rxrange 3 1030 1694
But I haven't heard of this being a problem with the FlySky version
Alternately - keep in mind that if you're moving from the normal inductrix to this - the motor layout is different. If you're using the stock inductrix frame you should rotate the board in betaflight to match the vanes on the ducts, if you're using the E010 frame ... don't worry about it.
Does that help?
Thanks I got is sorted out. Seems i had to change my end points on my transmitter. Never had this issue on a bigger brushless quad. Thanks for the info.
[-] The following 1 user Likes rcandvideogameguy's post:
  • sloscotty
  Help TinyHawk 2 Freestyle Rx issue Diesel79 3 155 27-Mar-2024, 09:15 AM
  Mobula 6 throttle issue with Tattu 300mAh HV batt husafreak 18 1,493 05-Mar-2024, 04:50 PM
Last Post: husafreak
  Build ACK80 Attack Chicken Walksnail with motor issue Cyberess 11 497 13-Feb-2024, 04:55 PM
  Help GEPRC TinyGO 4K FPV Whoop RTF Controller issue aiflai 14 6,436 10-Dec-2023, 05:48 AM
Last Post: LEM17
  Weird issue with Crux 1S, drops out of the sky Andreas-sa 7 275 17-Oct-2023, 10:44 PM
Last Post: V-22
