Threads: 10
Likes Received: 3 in 2 posts
Likes Given: 19
1 Hey guys I just got my beecore today. I got it bound up. I got the flysky one. But something seems off. The minimum values showing in clean flight are all 1024 not the normal 1000. I also had to use the subtrim the channels allot to get it centered but still the minimum is all 1024 for all channels. When I tried to maiden it today it flipped out of control too. Is there anything I can do to fix this. Thanks. I haven't had this issue on any of my other quads
Threads: 5
Likes Received: 52 in 29 posts
Likes Given: 22
5 I know for the DSM version, the built in RX has a limited ranges which you need to inform betaflight about with RXRANGE command (the exact values will depend on your receiver) - but after getting the maximum range in betaflight write down the numbers, narrow the range just a hair (if you can get 1024-1700 - for example - use 1030-1694)
then run the following command in CLI:
rxrange 0 1030 1694
rxrange 1 1030 1694
rxrange 2 1030 1694
rxrange 3 1030 1694
But I haven't heard of this being a problem with the FlySky version
Alternately - keep in mind that if you're moving from the normal inductrix to this - the motor layout is different. If you're using the stock inductrix frame you should rotate the board in betaflight to match the vanes on the ducts, if you're using the E010 frame ... don't worry about it.
Does that help?
Threads: 10
Likes Given: 19
1 Thanks I got is sorted out. Seems i had to change my end points on my transmitter. Never had this issue on a bigger brushless quad. Thanks for the info.
