Posts: 1,290 Threads: 67 Likes Received: 713 in 473 posts Likes Given: 1,216 Joined: Mar 2016 Reputation: 23 Greetings..... I was trying to decide the best way to place the battery on my latest build. If I place it "flat", the screws that hold the top plate on will dig into the battery as shown. Even with velcro between the battery and the plate, once you pull it down with the strap, I suspect it will still be digging into it...at least a little. Add viberation and movement and I could have a problem. If I mount it on it's edge..... That problem will pretty much be elimintated. However, it will raise the COG a bit. Even though approximately 80% of the battery will still be in the same spatial location, a little of it will extend above that, but it will not amount to a lot of weight. My inclination is to not worry about it, I don't think it will make a significant difference. Would appreciate hearing any thoughts/opinions anyone would care to offer. Thanks! "Damn the torpedoes!!! Full speed ahead!!!" • Posts: 2,416 Threads: 51 Likes Received: 1,861 in 1,175 posts Likes Given: 3,315 Joined: Mar 2016 Reputation: 74 22-Dec-2016, 10:50 PM (This post was last modified: 23-Dec-2016, 08:41 AM by sloscotty.) I've had the same concerns. I got some 2mm non-slip tape ( https://www.aliexpress.com/item/3cm-50cm...24691.html ). Most M3 button-head screws have 1.65mm thick heads, so this will help, I think. But I'm thinking about getting some even thinner low-profile hex screws (0.8mm head) like these: http://www.rcmart.com/3racing-tsfsm306al...39378.html. (Edit: Nope, not those. See post below.) (I've done away with all velcro - I'm using the anti-slip rubber tape, and anti-slip lipo straps.) Posts: 1,290 Threads: 67 Likes Received: 713 in 473 posts Likes Given: 1,216 Joined: Mar 2016 Reputation: 23 23-Dec-2016, 12:46 AM (This post was last modified: 23-Dec-2016, 01:12 AM by sirdude.) I was digging through my stuff and I found something that will work I think....didn't even know I had it...or for that matter where I even got it: Using this on the plate and the battery elevates the battery approximately 3/16" above the plate resulting in this: I think this will solve my problem. Appreciate the response Scotty! EDIT: I am going to pick up some of those screws and "dead" rubber you provided the links to....good stuff! Thanks! "Damn the torpedoes!!! Full speed ahead!!!" • Posts: 1,149 Threads: 50 Likes Received: 704 in 450 posts Likes Given: 1,189 Joined: Sep 2016 Reputation: 30 Just a small tip, i would cut that piece of velcro in half length-wise, and put it on so it lines up with the edges of the battery (with a gap in between). That way the battery sits a bit more stable, compared to when it's all in the middle. Posts: 1,290 Threads: 67 Likes Received: 713 in 473 posts Likes Given: 1,216 Joined: Mar 2016 Reputation: 23 Thank you for the input. It's not Velcro, it's something called duel lock that is more stable then Velcro (it doesn't compress like Velcro). Were it Velcro, I would agree with you 100%, but it's pretty stable like it is. It's a bit of an optical illusion too.....it's only in from the edges of the battery maybe an eighth of an inch at most. : ) "Damn the torpedoes!!! Full speed ahead!!!" • Posts: 2,416 Threads: 51 Likes Received: 1,861 in 1,175 posts Likes Given: 3,315 Joined: Mar 2016 Reputation: 74 (23-Dec-2016, 12:46 AM)sirdude Wrote: EDIT: I am going to pick up some of those screws and "dead" rubber you provided the links to....good stuff! Thanks! The screws I linked above are NOT the correct type (my bad, those are tapered). The ones I'm talking about are like this (These are Misumi stainless steel - not sure they can be found in aluminum.) Posts: 1,290 Threads: 67 Likes Received: 713 in 473 posts Likes Given: 1,216 Joined: Mar 2016 Reputation: 23 Got it, thanks Scotty. : ) "Damn the torpedoes!!! Full speed ahead!!!" • Posts: 5,315 Threads: 672 Likes Received: 3,155 in 1,743 posts Likes Given: 2,030 Joined: Jan 2016 Reputation: 139 yes in a crash the bolt will dig into the battery, that happened to me in a crash and the battery exploded... (not really just started smoking) Posts: 1,290 Threads: 67 Likes Received: 713 in 473 posts Likes Given: 1,216 Joined: Mar 2016 Reputation: 23 (23-Dec-2016, 08:22 AM)Oscar Wrote: yes in a crash the bolt will dig into the battery, that happened to me in a crash and the battery exploded... (not really just started smoking) I like the exploded scenario better, more......"colorful"! "Damn the torpedoes!!! Full speed ahead!!!" • |
