11-Jun-2017, 07:45 PM
Hi to everyone, how can I choose the right battery for my quadcopter? In terms of mAh, discharge rate and weight? I have a martian 3 250mm, emax rs2205s 2600kv, racestar 30A lite s and omnibus f4 v2
Battery help |
11-Jun-2017, 07:45 PM Hi to everyone, how can I choose the right battery for my quadcopter? In terms of mAh, discharge rate and weight? I have a martian 3 250mm, emax rs2205s 2600kv, racestar 30A lite s and omnibus f4 v2 11-Jun-2017, 09:28 PM Like almost everything else in quadcopters, the answer is relative. To me, it looks as if you want speed! 2600kv motors can really ask for a lot depending on props. I personally would look for something reputable with a 75c or preferably higher discharge rating in a 1500mAh capacity size. You may save a bit of weight with a 1300mAh pack but might see more voltage sag. Target weight between 150g and probably no higher than 180 grams seems to be most common for 250mm 5" builds. Personally I am a fan of Tattu's. Just my 2 cents 12-Jun-2017, 01:03 AM If you are looking for packs for every day practice, these are pretty good value. http://bit.ly/infinity-4s-1500mah |
Best Battery Option for Build - Begginer | Arkadius27 | 7 | 220 | 19-Mar-2024, 04:40 PM Last Post: Pathfinder075 | |
Smoke, Fire, and Sparks when I plug in battery | NickyWicker | 7 | 1,717 | 06-Mar-2024, 09:39 AM Last Post: home003 | |
4S vs 6S Battery Question | Coleon | 23 | 856 | 24-Feb-2024, 01:07 AM Last Post: iFly4rotors | |
How do FPV cars and planes transmit battery voltage to the pilot? | Brun0MF | 12 | 344 | 05-Feb-2024, 06:47 PM Last Post: Krohsis | |
Solved Pre-mature Low Battery warnings in my Avatar OSD | Seii-FPV | 45 | 1,617 | 03-Jan-2024, 04:11 AM Last Post: Seii-FPV |
