Hi guys,
Usually I fly my 5 inch quads (the Nazgul5 for example) with 6S 1300mah batteries, let's consider a weight of the quad of 470g and a weight of the battery of 225g. Total weight will be about 700g. No action cam for now.
With this setup, flight time is about 5 to 8 minutes depending on how much I push the throttle.
I bought also some 6S 1550mah in the past but I "feel better" with 1300mah...
Do you think I may get a better performance using a smaller battery like a 1050mah or 1100mah (weight would be about 180g) ? I would like to get a suggestion from you before buying new batteries.
In the near future I would like to use a Gopro9 without battery (~118g). With a total weight of about 820g the situation changes ?
Thanks
Thanks
