Bat-100 Review
Huge thanks to Sandra and BangGood for providing this item in return for an honest an impartial review.
The Fullspeed Bat-100
Available to purchase from BangGood here for only $99.99 -  https://goo.gl/vFLhUv
[Image: 7F0kGd5.jpg]
At a glance
The Bat-100 is a 1s (3.7v) micro quadcopter with 0705 15000kV motors, a 6 amp (7A burst) 4-in-1 ESC running DShot 600 digital protocol. The1.4mm thick carbon fiber chassis is configured in a 'streched X' format and measures 100mm from motor to motor. It comes PNP (Plug and Play) which means that you will have to solder your choice of receiver to the FC, but (unusually for a PNP model) it is supplied with a 500mAh 30C Li-Po battery, but no charger, so you will have to buy one separately if you don't already have one. This model visually resembles a much larger racing pedigree quad with its minimalist look, this minimalism is due to Fullspeed applying a Hollywood supermodel's obsessive attention to loosing weight!
[Image: cahzHUz.jpg]
Unboxing
The Bat is shipped in a sturdy cardboard box which contains molded foam to keep the model, props and battery well protected during transport. Supplied with 2 full sets of 55mm cool blue props to get you in the air, but I would suggest purchasing some spares as the model does not come supplied with any prop guards. In fact it is not supplied with much at all! The ready built model, battery, 8 props, 2 rubber bands and some Velcro to hold the battery are all that is included in the box. The lack of any instructions makes this hard to recommend as a 1st quad, and unusually there are no instructions or documentation linked from BangGood's product page either. Some experience with quad building and soldering really are a necessity to fit your own RX within the tiny frame. The carbon fiber chassis and top plate are very nicely finished with no rough edges and all the screws holding the model and components were all well tightened out of the box, though it is always a good idea to check this before flying.
[Image: RIwuHWT.jpg]
Receiver and Hardware Installation
The F3 flight control board has both 3.3v and 5v pads available on UART 3 to suit your choice of RX, I used the iRangeX clone of the FlySky A8S v2 RX, I de-cased it and used some insulation tape to ensure there were no shorts. The antenna on this RX is really far too long for this model, but I am still waiting for the postman to arrive with the micro RX I ordered to use with the bat... I disconnected the RX plug to solder the wires to the FC more easily, then plugged it back into the RX afterwards with only about 10-15mm of wire connecting the 2.
The solder pads are located on the 'front' of the FC, just behind the camera mount. The term 'mount' must be used lightly here as the AIO camera + VTX is simply stuck on with double sided foam tape, the camera on mine wan't even stuck on straight! The camera mount must be removed before soldering your RX to the FC, as the heat from the iron will be so close it will melt the 3d printed plastic.
Be very careful when moving the components, 2 wires (video and OSD) between the camera and FC became disconnected when I moved the camera and mount, believe me, I didn't put any tension or strain whatsoever on those wires! From this experience I think Fullspeed could do with a bit more time spent on quality control, checking the solder joints.
[Image: OcVcsqV.jpg]
Pre-flight and BetaFlight Setup
BetaFlight setup is very simple with this model, the F3 board has been pre-flashed with version 3.1 and has been factory configured with custom PID's and rates, you may wish to change these to suit your flying style though. All that is required in BetaFlight is confirming your RX is on UART 3 and configuring the type of signal your RX uses. The FC is compatible with SBUS, iBUS, PPM and DSM protocols. Before you go out flying, I'd suggest checking the orientation of the camera to confirm that it is level and facing straight forward, even slight misalignment can play havoc with your accuracy when proximity flying.
I have not managed to get BLHeli configurator to recognize the connection between the quad and my laptop yet, so I am unable to provide any info other than it using the DShot 600 digital ESC protocol. I will update this section when I have more information...
Tip - If you replace the foam tape that is provided to keep the camera secure, only stick the tape to the back of the camera, not the bottom.
[Image: 8KY9ABZ.jpg]
Not the prettiest soldering I have ever accomplished, but it works! Note to self 'watch out for the nylon standoffs!'
Flight Characteristics
The Bat 100 is FAST, surprisingly fast for a 1s model, this really is a great little quad for micro racing, even outdoors. Where many micro models, especially those running 1s batteries can feel slow when flying in large spaces, the Bat 100 really doesn't. It also has a buzzer and LED which makes it easier to find outside in long grass, showing that Fullspeed have designed this little guy to fly with confidence outdoors. It obviously wont keep up with a 5 inch all out racer, but the amount of speed the 0705 15000kv motors provide is very impressive. It is a little bit twitchy when flying FPV but I think much of that may be down to not following my own tip... I put foam tape on the back as well as the bottom of the camera when I put it back on (straight this time!) and after a few mishaps the camera can move and shake during aggressive maneuvers. I have some 650mAh batteries on their way to me now, some 35-70C Nanotech and 65C Turnigy graphenes, so I will test those, re-attach the camera and update this section soon...
[Image: dR9Mb5S.jpg]
Camera, VTX and FPV
I am very surprised at the range I can get out of the 25mW VTX on this AIO combo, I still have not managed to fly so far that I loose signal and I have flown over 70m away. I am pretty happy with the image from the 600TVL camera too, but it is nothing to write home about. It is OK at dealing with changes in lighting conditions, but at best, I would describe the dynamic range as 'acceptable.' Low light conditions are where this camera struggles, and I couldn't comfortable recommend late evening flying.
[Image: WFgySct.jpg]
Resilience
I haven't properly put the Bat through the wringer yet, I have had a few light impacts and dropped it from about 5M high with little ill effect. A bent prop which then broke after some aggressive direction changes gives the opinion that the stock props are not as durable as I would like, but I wouldn't go so far as to say they were 'flimsy.' Ladybird props are a good option, they are a little heavier than stock so they do have a very minor impact on flight time, I can honestly say there is very little difference in the motor temperatures (by feel) from using the Ladybirds over the stock props. They do feel like the have a bit more punch than the stock ones too, and they are also very durable, I would comfortably advise the ladybirds to be the 'go-to' prop for this model, the combination of power and durability really is very good.
[Image: tDEBkCC.jpg]
The carbon fiber used for the chassis on the Bat is very thin at 1.4mm, but as it is such a lightweight model (only 30g without RX and battery) it carries very little inertia into crashes so I hope that it can retain it's resilience through the heavier impacts that are (as always in this hobby) just around the corner!
[Image: pVl5n8i.jpg]
Prop guards are available to purchase separately (or 3d print your own) and if you are going to be using this model as an indoor flier I would strongly advise getting some, this model is very fast and I would recommend indoor use for experienced pilots only.
[Image: xd7rZWB.jpg]
Summary
I have been excited about the Fullspeed Bat-100 since I first saw it listed on BangGood, I was struck by its racing quad looks, light weight, brushless motors and the fact that it uses the same 1s 500mAh battery as the KingKong TiNY7. I have to say that besides there being no instruction manual and a little niggle over the QC of soldering of the camera wires, that I am very VERY pleased with how it performs. Incredibly fast and maneuverable, with plenty of power to recover from flips and tricks, and with a decent flight time. I can happily recommend this quad to anyone who has a little bit of experience with soldering and if you have only been flying whoop style 1s brushed quads this is your ideal progression for an outdoor model and a great introduction to the benefits of brushless motors. I have been struggling to put this thing down since I got it on Friday, now on Monday I have discharged about 30 packs through it already!
[Image: 0ILdKUA.jpg]
Pro's
Fast and maneuverable
Brushless motors
Super lightweight
Common size 1s battery
Great FPV range
A brushless quad that you can crash into yourself without injury!
Cons
No instruction manual
Needs better quality control on the soldering
Camera could do better in low light.
[Image: pqkm7BG.jpg]
[-] The following 4 users Like Tom BD Bad's post:
  • kaitylynn, Oscar, unseen, Snuffypot11
Quick update, I inverted the FPV image, and lost my VTX channel trying to turn it back, the AIO camera + VTX (VM 2751) is listed with channel frequencies and instructions here
I definitely want a micro brushless quad. Currently deciding between this, Oscar's "Angry Oskie" or the Boldclash B05. The Bat100 currently has me the most interested because of the OSD. Thanks for the review! I would love to see some outdoor flying if you have the time?
[-] The following 1 user Likes Snuffypot11's post:
  • Tom BD Bad
I will be uploading some some LOS and FPV flight footage to YT in the next few days... the weather has been a bit windy so just been playing under the trees in the garden...
  • Shaheed
As promised some FPV footage
[-] The following 2 users Like Tom BD Bad's post:
  • Snuffypot11, kaitylynn
WOW this thing can really move for it's size. Very impressive! And thanks for posting some footage.
I think I'll be ordering one in the coming weeks. What batteries have you been using? What C rating and capacity do you think is the sweet spot for a quad this size?
(02-Nov-2017, 06:43 AM)Snuffypot11 Wrote: WOW this thing can really move for it's size. Very impressive! And thanks for posting some footage.
Yeah, super fast and agile for 1s!!
I expect it behaves like something much bigger, (though I only have micro's so I couldn't say for sure) it was much more reassuring to fly acro, the extra power over what is delivered by the 720 brushed motors on my Tiny7 makes a huge difference.
(02-Nov-2017, 06:43 AM)Snuffypot11 Wrote:  What batteries have you been using? What C rating and capacity do you think is the sweet spot for a quad this size?
The stock 500 mAh 30c (same as the 'peakpower / weakpower' that came with the {pre-update batteries} Tiny7) is what is used for this flight, I just received 600mAh 65c Turnigy graphenes and 600mAh 35-70C nanotechs, I had to make up a converter for the plug which added another gram, seemed to add just enough weight to damage the bloody motors on flight number 2 with new packs!   Angry
People have been saying that these (not the right connector for the Bat) upgraded 450 mAh packs that are now shipped with the Tiny7 make a big difference, how much they would improve the Bat IDK?
FYI, I am ordering a set of the Sunnysky 0705 (with bearings not bushes) you can see the ball race here
[Image: RM8775-1-ba7c-5bL6.jpg]
they are almost double the weight heavier (~3g vs ~1.5g ~2.5g) of the stock motors so I don't know how they will fare, but I will let you know.
Another 2 month wait begins....
(02-Nov-2017, 08:33 AM)Tom BD Bad Wrote: seemed to add just enough weight to damage the bloody motors on flight number 2 with new packs!   Angry
What? That sucks! Did the motors burn out because it was too heavy?
I live in Aus and prefer to buy batteries locally if I can find them... can be hard sometimes. I'm was thinking of this Tattu 1S https://www.genstattu.com/tattu-75c-1s1p...-plug.html but haven't found somewhere that sells them in Australia yet.
Not burnt out... Just added a bit more weight to increase inertia in a crash... The top of the bell fits inside the sidewall of the motor, its not a single piece. So on impact the top slipped out slightly on one side so the rotor was slightly off kilter, I used long nose pliers to squeeze it back into place, and it worked..! Then the very next battery the same thing happened but one of the magnets slipped out of alignment, and that was all she wrote!
(02-Nov-2017, 09:15 AM)Snuffypot11 Wrote: I'm was thinking of this Tattu 1S https://www.genstattu.com/tattu-75c-1s1p...-plug.html but haven't found somewhere that sells them in Australia yet.
That does look like it could be a great option, if you do find a local supplier, let me know how they do (if you do end up getting one?)
Just an FYI regarding motors...
It looks like the racerstar 0705 size have been discontinued on BangGood, and they are sold out of the remaining stock of the 15000kV, however there is a listing for an 0706 15000kV brushless motor from happymodel ($7.29 individual price or $7.00 each for 4 ), on the scale showing 3.5g the extra weight of these over the stock (about 2.5g) motors suggests these could have bearings but I cannot find confirmation.
The Sunnysky 0705's which do have bearings are about $15 (per set) cheaper from RCmoment than BG have them listed ($44.99 vs 29.41 + shipping {which to South Africa was only $0.69})
Beware that there are complaints that these sunnysky's have the same problems with vibration and noise as the racerstar's, also according to this post at RCG the revised Bat-100 comes with the SunnySky motors as stock..?!
  • Snuffypot11
Finally I fitted my SunnySky 0705 15000kv motors and after 2 windy days I haven't flown it outside yet and not with goggles on either. So I was just hovering in the lounge, getting a feel for how the quad reacts with these new motors, and landed at low bat buzzer, a bit heavily I'll admit, but not nearly enough to be called a crash. Now one of the motors won't turn, there is more resistance turning it by hand than there was before the landing, but I can see no indication of damage. There is now a click/twang like there is a strand of wire getting caught on the magnets, but after successfully removing the C-clip (without damaging or losing it would you believe!) I can see nothing that would be causing this?
From my limited time flying with these motors, they squeal and loudly, I seem to get slightly shorter flight times, not sure if they are drawing more amps or it's just the additional weight?
For anyone who wants to take the C-clip off this tiny motor, I just used a flat precision screwdriver (just wide enough to fit between the ends of the 'C') and pushed, OK it wasn't quite as easy as it sounds Wink
Well I'm just going to put one of the working racerstars back on there and hope it's OK...! I think I will try the Happymodel 0706 for the BD Bat and BD Cat...
For a while, even after disconnecting your battery, the motors will be slightly harder to turn because the FETs on your ESC will still be turned on and acting as a brake. Here's a great demonstration by Bruce:
My motors don't squeal.
Also, if one of your motors won't start any more, are you certain that you managed to remove all of the varnish from the motor wires? Sometimes, you can get a connection, but it's not a reliable one and a knock will be enough to make the connection open up.
  • Tom BD Bad
(12-Jan-2018, 01:21 PM)unseen Wrote: Also, if one of your motors won't start any more, are you certain that you managed to remove all of the varnish from the motor wires? Sometimes, you can get a connection, but it's not a reliable one and a knock will be enough to make the connection open up.
Yeah, I actually had to re-solder the front 2 motors because I hadn't taken enough of the varnish off. The motor does twitch a little when arming and there is continuity through the motor to all the solder joints.
Thanks for the suggestions. The other motors don't feel noticeably harder to turn after dis-arming.
Its this clicking that has me baffled, I'll re-scrape the wires and try it again...
  • unseen
#15
When I took the FC off the stack one of the wires from the offending motor jumped off, scraped it and re-soldered, but still no joy. Actually, de-soldered all 3 wires, cut the tin off, melted the insulation and re-scraped the bare wires, but no. So replaced it with the RacerStar and it is working with the others, so I can fly! As long as the 'kin thing still works tomorrow when the wind dies down, then I can actually take it for a proper spin...
Thanks for your help man!
  • unseen
  VTX Quanum Elite QE58-2 5.8GHz 25-200mW VTX: Bench Review & RF Power Measurements Michael Grabner 3 2,488 03-Jan-2024, 02:31 AM
  100% aluminum 5” frame may actually be better than carbon?? Rob3ddd 23 3,681 08-Oct-2023, 11:58 AM
Last Post: iFly4rotors
  Announcement Orqa Acquires 100% Of ImmersionRC SnowLeopardFPV 7 1,011 29-Apr-2022, 05:24 PM
Last Post: klnyc
  OWLRC 5.8 GHz RC Antenna SWR Meter V2 Review & Test 1nformatica 6 3,344 23-Dec-2021, 07:43 PM
Last Post: jasc
  Bardwell's DJI Drone review........ yammahoppy 19 1,909 09-Mar-2021, 10:22 PM
Last Post: yammahoppy
