Armattan Chameleon Build Log
#31
I wonder if you damage the replacement, if the replacement of the replacement is free..... ROFL
#32
(30-May-2017, 12:07 PM)sirdude Wrote: I wonder if you damage the replacement, if the replacement of the replacement is free..... ROFL
It sure is!
  • Drone0fPrey
#33
Hi!
About to order an Chameleon myself. I love the Runcam Eagle, so I found this Smile
https://www.thingiverse.com/thing:2351841
Should do the trick!
[-] The following 1 user Likes roika's post:
  • unseen
#34
(06-Jun-2017, 02:04 PM)roika Wrote: Hi!
I just did the modification last night.  A new X-acto knife cuts through the rubber mount like butter, making it quite easy to modify.  A sharp chisel also helps if you have one.
If you have a 3D printer then that is probably the way to go though
[-] The following 1 user Likes QuentinT's post:
  • R.C.Papa1
#35
Good find. It looks like a pig to print though...
#36
(06-Jun-2017, 05:04 PM)unseen Wrote: Good find. It looks like a pig to print though...
Got a buddy to print it for me, worked out great. I would recommend printing in flex tho, the once I got was kind of hard to work with.
[Image: 3.jpg]
[Image: 2.jpg]
[Image: 1.jpg]
[-] The following 2 users Like roika's post:
  • unseen, sloscotty
#37
Nice!
The whole idea of the 'dimes' being made in flexible material is to isolate the camera from vibration, so I'd certainly be looking at printing some with flexible filament.
Once I have my main printer back online, I'll see how horrible these are to print in Ninja Semiflex.
  • roika
#38
I was wondering if you were able to hook up S.port telemetry and SmartAudio in addition to SBUS with this flight controller.
Also, are you using the OSD? How is it? Anyone using BetaFlight with this FC or is everyone using dRonin?
#39
Nice build.  I did one about 6 months ago.  I went with Betaflight FW.  This was one of the most difficult tune I had to do.  It took a while, but I was able to get it flying properly.  Well build frame.
I used a Runcam Swift, so I did not have trouble with the lens going pass the cage.
[Image: EByg8m9l.jpg]
[Image: WqQRyaXl.jpg]
  • unseen
#40
(01-Oct-2017, 12:20 AM)keithws Wrote: I was wondering if you were able to hook up S.port  telemetry and SmartAudio in addition to SBUS with this  flight controller.
I did hook up all three. S.BUS to the receiver port at the bottom of the board, SmartPort to the multiport's TX pin and SmartAudio to the serial port on the right hand side of the board. All according to the manual.
I can't remember if all of them worked. I'm using dRonin on the RE1.
At the moment, my Chameleon is dismantled. Originally, I used a Unify Pro powered from the mPB's filtered 5V output, but I got horrible diagonal lines on the FPV video, so bad that they made it hard to fly in FPV. I'm going to try using a Unify Pro HV instead and either power it from the mPB's filtered battery voltage pins, or directly from the battery if that doesn't make the video noise go away.
#41
(01-Oct-2017, 08:25 AM)unseen Wrote: I did hook up all three. S.BUS to the receiver port at the bottom of the board, SmartPort to the multiport's TX pin and SmartAudio to the serial port on the right hand side of the board. All according to the manual.
Thanks for replying. Good thing I already bought the HV version of the Unify Pro! ;-) I think I’m gonna go for it.
#42
(02-Oct-2017, 03:12 AM)keithws Wrote: Thanks for replying. Good thing I already bought the HV version of the Unify Pro! ;-) I think I’m gonna go for it.
Please tell us how it works for you.
#43
(02-Apr-2017, 05:06 AM)SwissFreek Wrote: I have a question: one of the reviews I watched on YouTube remarked that the RunCam Swift RR Edition doesn't fit the molded rubber bits that hold the camera angle, because the back of the camera isn't "long" enough to seat completely into the molded notch, so the camera has room to wiggle around. Have you found that also to be the case with the Eagle? I've got a Chameleon on the way, and the Eagle would be my first choice, but I think I read somewhere that the Chameleon was actually designed with the Foxeer Monster or Arrow in mind?
I have runcam swift RR edition and I think it fits fine. You just have to change the back plate (It comes with an extra plate which is flat)
  Build Rekon5 UL 5" build ph2t 51 7,978 12-Apr-2024, 02:26 AM
Last Post: ph2t
  Build Micro Apex 4" Build drumgod 8 387 11-Apr-2024, 12:05 AM
Last Post: BigBeard
  Build Helios - 3.5” Sub-250g (Sub 160g possible) DJI O3 Drone – Frame/Build Thread Recursion 12 1,851 25-Mar-2024, 10:28 PM
Last Post: Recursion
  Build 5in lightweight build hawk01 37 1,359 22-Mar-2024, 10:56 AM
Last Post: Jossey
  Build Whoosh - 3.5" build. PID settings? maxer 23 1,164 30-Dec-2023, 08:29 PM
