Posts: 634 Threads: 56 Likes Received: 335 in 196 posts Likes Given: 183 Joined: Mar 2016 Reputation: 15 15-Nov-2016, 05:06 PM (This post was last modified: 23-Nov-2016, 12:40 PM by Grisha0.) i have a riddle for you... i've found a solution to it... so the task is simple why the hell it is not arming or arming randomly ? All the best Grzesiek (Grisha/ Greg) Curently flyable: Nox 5, Minimalist 112 Bench / in progres: fixing Nox 3, Scrap thinking about building: 450 • Posts: 1,290 Threads: 67 Likes Received: 713 in 473 posts Likes Given: 1,216 Joined: Mar 2016 Reputation: 23 Both of my Naze32's are finicky like that. "Damn the torpedoes!!! Full speed ahead!!!" • Posts: 5,319 Threads: 673 Likes Received: 3,155 in 1,743 posts Likes Given: 2,031 Joined: Jan 2016 Reputation: 139 is the TX working properly? checked receiver tab for channel values yet? • Posts: 1,149 Threads: 50 Likes Received: 704 in 450 posts Likes Given: 1,189 Joined: Sep 2016 Reputation: 30 (15-Nov-2016, 06:09 PM)Oscar Wrote: is the TX working properly? checked receiver tab for channel values yet? Throttle not reliably low enough? Other than that... FC CPU usage? • Posts: 1,070 Threads: 70 Likes Received: 742 in 378 posts Likes Given: 577 Joined: Jan 2016 Reputation: 44 Yup, looks like throttle is above min. Thats on raceflight right? I found it more picky on min throttle settings than betaflight. • Posts: 634 Threads: 56 Likes Received: 335 in 196 posts Likes Given: 183 Joined: Mar 2016 Reputation: 15 15-Nov-2016, 08:09 PM (This post was last modified: 15-Nov-2016, 08:10 PM by Grisha0.) please note that it arms without any changes in the configuration, you have seen i've flipped the arm switch few times, no reaction... then it armed (and i had a small hearth attack), yes this is on raceflight... if it changes anything for your guessing All the best Grzesiek (Grisha/ Greg) Curently flyable: Nox 5, Minimalist 112 Bench / in progres: fixing Nox 3, Scrap thinking about building: 450 • Posts: 1,070 Threads: 70 Likes Received: 742 in 378 posts Likes Given: 577 Joined: Jan 2016 Reputation: 44 Then check receiver tab as Oscar suggested. You may have throttle jumping by 1-2us and theoretically it can refuse to arm. You'll have to fiddle with min_command and min_throttle • Posts: 634 Threads: 56 Likes Received: 335 in 196 posts Likes Given: 183 Joined: Mar 2016 Reputation: 15 nope that is not it All the best Grzesiek (Grisha/ Greg) Curently flyable: Nox 5, Minimalist 112 Bench / in progres: fixing Nox 3, Scrap thinking about building: 450 • Posts: 2,416 Threads: 51 Likes Received: 1,861 in 1,175 posts Likes Given: 3,315 Joined: Mar 2016 Reputation: 74 (15-Nov-2016, 09:11 PM)Grisha0 Wrote: nope that is not it Didn't realize this was a guessing game Your throttle trim (on TX) was up a bit? (You were hiding that with your hand... • Posts: 634 Threads: 56 Likes Received: 335 in 196 posts Likes Given: 183 Joined: Mar 2016 Reputation: 15 trims were not touched and had no impact on arming yup kind of a mindcheck - based on limited amount of information deducting what could be the root cause All the best Grzesiek (Grisha/ Greg) Curently flyable: Nox 5, Minimalist 112 Bench / in progres: fixing Nox 3, Scrap thinking about building: 450 • Posts: 1,070 Threads: 70 Likes Received: 742 in 378 posts Likes Given: 577 Joined: Jan 2016 Reputation: 44 15-Nov-2016, 10:08 PM (This post was last modified: 15-Nov-2016, 10:10 PM by KonradS.) More important question is - why are the ESCs playing initializing tone twice? EDIT: aaah guessing game! I think solar flares have affected the time continuum. When you flipped the switch for the first time, it armed. Just a few seconds later. Following switch flips were just a coincidence. Just like your heart attack • Posts: 2,416 Threads: 51 Likes Received: 1,861 in 1,175 posts Likes Given: 3,315 Joined: Mar 2016 Reputation: 74 In both videos, it only armed after you moved the switch all the way down, then up, then down to middle position. So something is turned on (or off) when you go to the bottom that allows it to arm on next switch to the middle. (What that would be I have no idea....) • Posts: 634 Threads: 56 Likes Received: 335 in 196 posts Likes Given: 183 Joined: Mar 2016 Reputation: 15 this switch is 3 pos: 1. Disarm 2. Arm (airmode, skitzo etc) 3. Arm (airmode, skitzo etc) + Blackbox however... i can remap it to 2 pos and the behavior will not change... the double initialization as its origin is not clear to me why... has no impact on the "house flying" so far. @Konrad, i like the creative approach... but not, it is much simplier than quantum physics All the best Grzesiek (Grisha/ Greg) Curently flyable: Nox 5, Minimalist 112 Bench / in progres: fixing Nox 3, Scrap thinking about building: 450 • Posts: 2,416 Threads: 51 Likes Received: 1,861 in 1,175 posts Likes Given: 3,315 Joined: Mar 2016 Reputation: 74 17-Nov-2016, 01:49 PM (This post was last modified: 17-Nov-2016, 01:52 PM by sloscotty.) So Grisha, what is the answer to this riddle? Inquiring minds want to know... [BTW, you should enter this thread in the contest (I think it qualifies). You will be way in the lead...] • Posts: 634 Threads: 56 Likes Received: 335 in 196 posts Likes Given: 183 Joined: Mar 2016 Reputation: 15 sorry for not replying for past 48h was in emergency mode at work.. i'll wait a few more ideas and then ill post the answer maybe some more intriqued mindsets will jump in as for the contest... lol didn't think of that... All the best Grzesiek (Grisha/ Greg) Curently flyable: Nox 5, Minimalist 112 Bench / in progres: fixing Nox 3, Scrap thinking about building: 450 • |
