I got 2 MXK PDB with OSD from Banggood, and one works perfectly, but I am not able to flash MWOSD on the second one. I get this error message in the Arduino IDE:
http://www.banggood.com/MXK-Power-Distri...31375.html
Sketch uses 25,962 bytes (84%) of program storage space. Maximum is 30,720 bytes.
Global variables use 1,901 bytes (92%) of dynamic memory, leaving 147 bytes for local variables. Maximum is 2,048 bytes.
Low memory available, stability problems may occur.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xad
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xad
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xad
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xb9
I get the same error when trying to flash my beerotor OSD with a FTDI adapter. The Beerotor OSD works fine, but I am not able to configure ut from my computer.
I have tried with MWOSD 1.5, 1.6 and ScarabOSD 1.5, 1.6 (shouldn't make any difference when flashing with arduino IDE).
I also got the same problem when trying to flash my Openlog SD card writer with the Blackbox software
