Aoyue 2930 Programmable Lead Free Soldering Station is the soldering station I decided to go with. Here is teh feature set that sold me on it as well as the excellent price:
This unit is Microprocessor controlled, with touch-type temperature adjustment and memory presets.,Auto Sleep and Wake Functions, Vibration sensor in the iron handle that detects movement Digital Offset Programmable Sleep Function System Lockout Feature to make it child safe, 24 volt output to prevent circuit damage, ESD Safe, CE and RohS Compliant design
The heat is very VERY fast and stays consistent through use. It is very fast to heat up when turned on (about 5 - 10 seconds).
- Has excellent thermal recovery allowing Easy lead-free soldering
- 75 watt Power consumption
- Integrated Tip, Heater Cartridge and sensor
- Programmable sleep function and 2 programmable quick jump temperature presets
- Reads in Centigrade or Fahrenheit
I am a developing Racer - getting better.....
BNF Quads: <250 Eachine>; <250 Walkera Advanced CC3D>; <250 Vortex Pro>
Built: Dronz Fury 252 RX ; Speed Addict 210-R
Building: <Deciding on Third build - Suggestions?>
