Threads: 66
Likes Received: 350 in 248 posts
Likes Given: 164
34 I was looking for a antenna that is a bit more sturdy robust than the aomway antenna, so I ordered a DYS CP from banggood. Here is a quick comparison between the Aomway and DYS antenna and it actually looks like the DYS is doing better than the aomway
Threads: 10
Likes Received: 20 in 12 posts
Likes Given: 14
3 Nice, did you use this?
http://www.banggood.com/DYS-FPV-5_8G-Ant...65852.html Excellent price
. Which RX antenna did you use? Thanks
Build - Fly - Crash - Repeat
Threads: 66
Likes Given: 164
34 yeah, that is the antenna. It is not as though is I thought it would be. I had the case open due to a prop strike, but I taped it up with some electrical tape. I think t will hold just fine if you tape it before you use it. I am waiting for a Foxeer antenna as well which i will try do a similar test with, as well as a TBS triumph borrrowed from a friend in the near future..
The VRX was the Realacc RX5808 diversity without the second module (non diversity) paired with a Aomway antenna. I'm waiting for a immersion RC patch antenna to fit on the diversity module.
Threads: 10
Likes Given: 14
3 20-Sep-2016, 09:39 AM (This post was last modified: 20-Sep-2016, 09:39 AM by phara.) My idea (as I really like the Aomway atennas): 3D printed case for it with some polyurethane foam in it. This should be indestructible. The foam is not conductive so it shouldn't reduce the range. Am I missing something?
Threads: 23
Likes Given: 56
8 I've just bought a couple of the DYS antennas based on this video, thanks for sharing it.
Current quad: ZMR 250 / DYS SE2205 / Littlebee 20A ESCs / Drone Lab 1500 4S / Naze32 Rev5 / BF 2.7.1
Check Out My Build<<<<<<<<<<
Threads: 10
Likes Given: 14
3 (20-Sep-2016, 11:03 AM)oyvinla Wrote: I found a video on youtube where a guy used gorilla glue mixed with water to make a foam-like substance he used on the lobes of the antenna and made a kind of ball of this sticky stuff. When it was cured, it was hard and light. I have ordered some gorilla glue to try this out myself. I couldn't find the video right now
I you'll ever find it again, please share
