Aomway TX001 Adjustable 5.8G 40CH FPV Transmitter
A new switchable power output VTX by Aomway is on BangGood. Its a 5.8G 40 channel It can be changed from 25mW to 200mW to 600mW of power output.  One of the cool features I see is that you can get an optional 50mm SMA extension without the need for a Pigtail. This should be useful to save wait while also protecting your VTX.
(From BangGood description)
Brand Name: Aomway
Item Name: TX001 Transmitter
Frequency: 5.8Ghz
Power Adjustable : 5.8G Switchable  25mW/200mW/600mW
Channel: 40CH 5658-5945mhz (Raceband)
Wide Power Input: 6-28V
Current: 12V/200mW/150mA
Channel&Frequency Adjustable Button
Indicator LED to show the frequency and power
Mic: Swithable, when open the Mic., it will occupy one audio channel
Output Voltage: 4.9-5.1V for camera
Audio:  Stereo Output
Format: Auto regonize NTSC/PAL
Connector:  TX001A SMA short conenctor;TX001B 50mm SMA extend cord connector
Dimension: 29x25x10mm
Weight(without antenna): TX001A: 11g
                                              TX001B: 12g
This VTX only weighs 11g or 12g with the pigtail. Compare that to a 600mW immersionrc VTX that weighs 18g
One thing that seems concerning is the solder joint on the SMA connector. It looks quite sloppy. Hopefully that is just the one sample and the other ones will be better
http://www.banggood.com/Aomway-TX001-Adj...74772.html
[-] The following 1 user Likes Xtopher98's post:
  • Oscar
Anyone used this vtx?
The description says about mic, however, where is the mic?
i don't think it does can't find it on the unit.
also it has audio inputs means it probably doesn't have a mic built-in.
looking good, lacking information is it sma or rpsma
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
(18-Sep-2016, 08:12 PM)Grisha0 Wrote: looking good, lacking information is it sma or rpsma
Quote:Connector:  TX001A SMA short conenctor;TX001B 50mm SMA extend cord connector
Well being blind didnt help Smile
Thanks for pointing it out
All the best
Any other users of this VTX? Curious on heat dissipation and any issues folks are facing.
  orqa fpv.pro ? hugnosed_bat 3 481 22-Sep-2023, 01:03 AM
  Surprise! Looking for free trial fpv player! ifpv much 0 323 08-Feb-2023, 08:52 AM
Last Post: ifpv much
  Is it possible to build an fpv drone within 150 dollars? ifpv much 31 2,067 08-Dec-2022, 06:54 PM
Last Post: burkeomatic
  Full MSP OSD for DJI FPV System - Now available! V-22 16 5,485 05-Dec-2022, 04:35 PM
Last Post: fpvapnea
  Are you willing to try a new brand of FPV products ifpv much 12 857 24-Nov-2022, 05:58 PM
Last Post: iFly4rotors
