28-Jan-2024, 04:17 PM (This post was last modified: 30-Jan-2024, 01:06 AM by skywanderer.)
Ran across this vid from the preview stack while watching a different unrelated one...
...went to his linked N100 page @ amazon, saw that it was unavailable but this was:
GMKtec Mini PC, Intel Alder Lake N100 Windows 11 Pro (3.4GHz), 8GB DDR4 RAM 256GB PCIe M.2 SSD, Desktop Computer 4K Dual HDMI Display/4x USB3.2/WiFi 6/BT5.2/RJ45 Ethernet Nucbox G3 - $159.89
https://www.amazon.com/GMKtec-Mini-PC-Co...B0CH81C4K3
adding a couple more with speedy DDR5 ram:
AWOW Mini PC Intel Gen12 N100 Quad Core 3.40GHz, 8GB DDR5 4800MHz 256GB M.2 SSD Mini Desktop Computer, Micro PC Dual Display HDMI DP 4K@60Hz Dual Gigabit Ethernet, WiFi5/BT5.2/ USB3.1 - $149.99
https://www.amazon.com/AWOW-3-40GHz-4800...B0CJDVW89L
GMKtec Mini PC Windows 11 Pro Intel N100 (3.4GHz) 4C/4T, Dual LAN Mini Desktop Computer 12GB DDR5 512GB Hard Drive, Micro PC 4K, Triple Display, WiFi6, BT5.2, Energy Efficient Nucbox G2, Red/Black - $189.89
https://www.amazon.com/Mini-PC-Computers...B0CCD3NMZ4
...hmmmm why not run your printer from something like this? Is there a “load Klipper from Linux” option available for the unschooled like me?
...hmmmm... interesting... discovered "mini-itx case" for other options enabling easier electronics enclosure building than the diy makerbeam route I took.
What would be ideal in my mind atm would be an easy to cobble alternative t /something similar to say Pad 7 or Creality Sonic Pad. This seems to be totally doable and should have much better performance even being able to output to a regular flat screen monitor vs touch pad?...
Ideas?
edit to add:
yeup someone has been there, done that:
Klipper 3d printer firmware easy install using Kiauh on a mini pc
...another dot done...
Ideas?
edit to add:
