Alien f3
Hi I got the Alien F3 board in the mail yesterday and I am having a problem with it.
This is the board I have.
http://www.readytoflyquads.com/alien-f3-...controller
I have a lemonRX sat pluged in and it binds but in betaflight the controller RX will not do anything. I have uart2 on for RX Ser, 2048, and nothing is moving in the config.  Huh Poop
After binding, you might try unplugging the USB from the FC, turn on the transmitter, then plug in the USB and connect.
(16-Nov-2016, 04:36 PM)sloscotty Wrote: After binding, you might try unplugging the USB from the FC, turn on the transmitter, then plug in the USB and connect.
OK I will give this a try. It is just strange that my radio is not showing up.
Still no dice. The rx tab is still not doing what it should.
  Build ImpulseRC Micro Alien 3” & 4” Lemonyleprosy 26 1,916 30-Oct-2021, 09:14 PM
Last Post: Lemonyleprosy
