03-Apr-2018, 09:17 AM
Anyone have a relative close number I can use for the current scale on the Aikon AK32 4in1? Right now the default 400 shows it consuming way more mah than it really is. Thanks in advance.
Aikon AK32 Current Scale? |
03-Apr-2018, 09:17 AM Anyone have a relative close number I can use for the current scale on the Aikon AK32 4in1? Right now the default 400 shows it consuming way more mah than it really is. Thanks in advance. 08-Apr-2018, 04:00 AM I have always started around 240. Most of my CL Racing F4 boards, and my Betaflight F4 boards have been around that number. Try starting with that, and run until it says about 500mah used, then re-charge and check. Should be pretty close at least! 13-Apr-2018, 11:34 AM Maybe take a look at this guide how to calibrate current sensor: https://oscarliang.com/current-sensor-calibration/ Another thing to note is that if you have ESC telemetry enable, you will have to change the current sensor type to ESC sensor, not onboard ADC |
ESC current sizing rule of thumb? | B4tn | 16 | 709 | 19-Jun-2023, 04:12 AM Last Post: B4tn | |
Whats up with my current amp draw reading? | MajorKook | 2 | 196 | 13-Jun-2023, 01:28 AM Last Post: MajorKook | |
Help Current Meter Problem with T-Motor F7 Mini Stack | ÄndyRändy | 25 | 6,230 | 30-Jan-2022, 05:17 PM Last Post: repli | |
Why 63.5A Limit on ADC current reading (Amperemeter Apere Meter) | jasc | 8 | 1,078 | 22-Sep-2021, 11:30 AM Last Post: SnowLeopardFPV | |
Unknown Motor Current Draw 2550Kv 2207 motor | Kadirjabbar | 9 | 972 | 03-Jul-2021, 10:45 PM Last Post: voodoo614 |
