25-Dec-2017, 09:20 PM
Hi Friends,
Am about to build an Agriculture spraying uav with a 5 liter tank capacity. Reason for 5L capacity is because a 5L tank with spray system is readily available at aliexpress. I ve been searching for information on the setup since a while but got confused in many a things. They say the more you search the more you get confused. So my problem here is decide everything from frame to FC. The setup what I thought that ll work is as follows. Tarot X4 960mm, sunnysky 340Kv motors, 60a esc, 18-22 inch props, 22V 10000mah battery, Pix Hawk Controller. But I am not enough confident of this configuration that it ll work. I am restricted to build a Quad coz we have a very tight budget (as usual). So please help me in deciding for the best suitable configuration for this setup. Thanks in Advance.
