Found this Taranis Mod on Facebook, someone used Lua script to add a channel chart to the Taranis screen !
Wish someone can make it allow user to select the channel they are using so you don't have to be looking at your switches to determine where you are. I think this should be doable to make the script write to the EEPROM to save data. this would be awesome, as this can open up the possibility to allow you to select the current channel and show you all of the channels that are close in frequency as well.
Project page: http://helpmefpv.com/2016/03/16/5-8ghz-v...y-taranis/
