13-Jan-2016, 01:52 PM
Is anybody using it?
I'd like to understand what it really is and the beneffits using it...
Acro+ mode (raceflight) |
13-Jan-2016, 01:52 PM Is anybody using it? I'd like to understand what it really is and the beneffits using it... 13-Jan-2016, 02:04 PM (13-Jan-2016, 01:52 PM)Adriano Dias Wrote: Is anybody using it? I used Acro+ on OpenPilot and it should be something similar on Race/Betaflight. I will test it as soon as the weather is good enough to fly and i don't have to work when it's still bright outside. The feature adds some "manual input" to the mix. So when you roll at max Stick let's say 720°/s your quad will accelerate to that point and keep on turning with that rate. When you add Arco+ the motors will additionally see some percentage of manual input (like 10% power to the left motors in case of a right roll). This will increase your roll/pitch rates! TL;DR Add some manual output to the "PID-driven" one to have higher rates. A bit like expo. In Openpilot it activated only after a certain stick deflection. So you could basically fly low rates (360°/s), but when you pushed the Stick all the way it still turned with 1000°/s and more. If i gote something wrong, please correct me! Cheers Diego Sky is where the fun begins! Flying: Armattan F1-6 / Cobra 1960kv / KISS / 1800mAh nano's / SPR3 / Betaflight 2kHz Building: FPV49v4 modified |
Quad won't Arm Low Power Mode Unable to record videos | Seanalami | 3 | 549 | 27-Mar-2022, 11:13 PM Last Post: SnowLeopardFPV | |
TBS CROSSFIRE TX LITE is stuck in binding mode | Seanalami | 3 | 780 | 26-Mar-2022, 12:56 PM Last Post: Seanalami | |
Betaflight, Cleanflight, and Raceflight | raspberrypi33 | 8 | 2,877 | 03-Nov-2017, 03:05 PM Last Post: raspberrypi33 | |
Acro settings? | raspberrypi33 | 8 | 1,473 | 03-Nov-2017, 01:58 PM Last Post: Carl.Vegas | |
Help Drifting in level mode | DannyZ | 4 | 1,565 | 02-Sep-2017, 08:59 PM Last Post: fftunes |
