11-Mar-2019, 01:18 AM (This post was last modified: 11-Mar-2019, 01:28 AM by SnowLeopardFPV. Edit Reason: Typo corrections. )
Let my recent schoolboy mistake be a lesson for others to heed so it doesn't happen to them.
I'm always pretty safety conscious and I always considered that making sure the throttle was raised while disarmed was a good enough safety mechanism to prevent accidental arming. Lapse of concentration and not remaining focused led to the following sequence of events occurring.
So, I powered up my quad, switched on the transmitter ready to take off and then realised the angle of my FPV camera had got knocked out of position in the last hard landing. Instead of doing the sensible thing of unplugging the quad and switching off my transmitter, I stupidly just turned round and crouched down to get a hex driver out of my backpack with the transmitter still hanging around my neck.
The next thing I know is that I hear a few beeps followed by the roar of props. It took a few seconds to register in my brain what was actually happening but I turned back round to see my quad had shot way up into the air and seemed to be disappearing fast into the sky. Blackbox data shows throttle got knocked to 53% and it went to a height of almost 30 metres (100 feet). You can also see from the log that even after the throttle was cut (21 seconds into the video below), the quad had so much upwards momentum that it went up another full 13 metres in 2 seconds with no thrust from the props (as shown by the Barometer reading on the right of the video). That's how fast it was going up into the sky.
Panic immediately set in with some choice censored words spoken, but thankfully I fairly quickly managed to get everything back under control before I ended up my quad on the railway line behind me. It was lucky I hadn't manage to also knock the pitch/roll stick so at least it had only shot straight up and not flown off somewhere and ended up crashing out of control. For a split second I did consider just flipping the kill switch but I didn't really want to voluntarily drop it from that height onto the hard concrete surface of the skateboard park below, so after a bit of grappling and fumbling with the transmitter I managed to get the quad back into Angle Mode, drop the throttle and then get it safely back down to Terra Firma which it should never have left in the first place.
Needless to say, the whole episode scared the out of me and everything happened so quickly that I hardly had time to think. I'm lucky I wasn't standing over the quad when that happened otherwise I'd probably be writing this from a hospital bed. I certainly won't be making that same mistake again in a hurry. I'm generally really careful with procedures but it just goes to show that a small lapse in concentration or discipline could result in some catastrophic consequences. I could never see any real need for a pre-arm switch but after this, I'm now seriously considering adding one to my models just an an extra safety measure.
Lessons to be learned from this are:-
This is a running video of the Blackbox data log:-
- ALWAYS stay focused and remain disciplined with what you're doing.
- NEVER walk around with a switched on transmitter dangling from your neck.
- UNPLUG your quad immediately and also SWITCH OFF your transmitter if you need to abandon take-off for any reason.
- Don't assume that putting the throttle stick up when disarmed is a good enough safety measure to prevent accidental arming because it's NOT.
- Consider configuring a PRE-ARM SWITCH for added safety/security.
