808 #16 V3 camera
Hi, I have 808 #16 v3 camera. When recording, camera works about 1 minute and then turns off automatically. After that, it can not be used for next 1 hour, sometimes more.  After approximately 1 hour it can turn on again and start recording, and recording again takes only about 1 minute and so on. I press reset button, update, I do everything except open the camera and I really dont know what to do. Do you know what is the problem? Please.
Sorry for my bad english.
Does connecting it to USB make any difference? Are you able to read/write data while the camera is "asleep"?
Check out Chuck Lohrs Website.
There you can check if you bought a fake one or not. Maybe a firmware upgrade will help.
Build - Fly - Crash - Repeat
(05-Sep-2016, 01:53 PM)phara Wrote: Does connecting it to USB make any difference? Are you able to read/write data while the camera is "asleep"?
I can connect only for first minute and then automaticly turn off, the same as when i turn on for recording. And when camera turn off, I cant connect it for about 1 hour.
It is not fake, I check, thank you.
It work good for about 6 months and then just started to extinguish. I try to upgrade firmware and when I need to wait camera to turn off automaticly, it just dont want, then I need to disconnect it from computer and connect again..so I dont know if firmware is upgraded or not.
If I update firmware, I need to update all 3 firmwaves (mov.,avi.,__) or only one I use?
Than you.
You may see that the firmware is updated as your time and date should be resetted.
Did you flash the appropriate firmware to your camera? You need to double check that as this could damage your camera. Other than that I don't really know what else to do - sorry!
  Meteor 65 pro replacement camera NewToFPV 19 374 Yesterday, 06:19 AM
Last Post: NewToFPV
  Swapping Caddx camera's Jelle 1 86 16-Apr-2024, 10:48 AM
  Camera View on DJI Fly for non-DJI drone fwpsam 2 147 01-Apr-2024, 05:43 PM
Last Post: fwpsam
Exclamation Analog Camera Question / SBF7V3 Coleon 4 279 20-Feb-2024, 08:38 PM
Last Post: Coleon
  Any experience fixing VTX? Camera? romangpro 0 150 25-Oct-2023, 03:38 PM
Last Post: romangpro
