Threads: 1
Likes Received: 0 in 0 posts
Likes Given: 0
0 I'm considering a 6″ quad build using 24a KISS ESCs and the lumenier 2206 2000kv motor. Does anyone foresee any problems running with 6 inch props and this ESC? Does it match the current draw? I want the ease of KISS FC alongside KISS ESC running DShot but don’t want to blow ESC with the power draw of 6 inch props. Have scoured Internet and found people using 20-30a ESCs. This is not my first build, but is my first 6 inch and I don't want to blow the ESCs. Any advice would be much appreciated.
Threads: 67
Likes Received: 711 in 472 posts
Likes Given: 1,216
23 I am assuming 4S and you did not state the pitch of the props. You might get away with it because I am sure there is a safety factor built in to the ESC, but I looked at some of the test available on line and it seemed to me that 6" was right at 24 amps in many cases. For me, I would go for 30A and I wouldn't have to worry about it.
Threads: 83
Likes Received: 533 in 271 posts
Likes Given: 498
30 sirdude was hitting on a very good point, which is, the pitch of the props, a 4.5 pitch will draw more amps than a 4 or 3 pitch, and I agree with going 30 amps if you can, just assures a little more overhead, in saying that though, 24 amp will be enough as hardly anyone is full throttle 100% of the time and thus you wouldn't normally exceed the 24's burst mode.
