4" quad with lumenier 1806-2500kv
Hi
i really need some help tuning my 4" quad. The quad is lightweight and have good punch, but feels "sluggish"/not locked in on roll, pitch and yaw.
Frame: Diatone Spadger 180
Motors: Lumenier 1806-2500kv
ESC: Littlebee 20A blheli 14.4
FC: SP Racing F3 EVO
RX: Frsky d4r-ii
TX: Aomway 200 mW
CAM: HS1177
Weight: 220 grams
Prop: HQ 4x4x3
Firmware: Cleanflight 1.12.1 (Sadly not betaflight, because of PPM bug on my EVO fc)
Link to log: Log file
Link to cam video+log overlay: Video file
I really appreciate any help  Smile
CLI
# Cleanflight/SPRACINGF3EVO 1.12.1 Apr 10 2016 / 19:37:44 (236c7b9)
# dump master
# mixer
mixer CUSTOM
mmix 0 1.000 -1.000 0.768 -1.000
mmix 1 1.000 -1.000 -0.768 1.000
mmix 2 1.000 1.000 0.768 1.000
mmix 3 1.000 1.000 -0.768 -1.000
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -CURRENT_METER
feature -ONESHOT125
feature -BLACKBOX
feature -TRANSPONDER
feature RX_PPM
feature VBAT
feature FAILSAFE
feature TELEMETRY
feature CURRENT_METER
feature RSSI_ADC
feature ONESHOT125
feature BLACKBOX
# map
map AETR1234
serial 1 4 115200 57600 0 115200
led 0 15,15:ES:IA:0
led 1 15,8:E:WF:0
led 2 15,7:E:WF:0
led 3 15,0:NE:IA:0
led 4 8,0:N:F:0
led 5 7,0:N:F:0
led 6 0,0:NW:IA:0
led 7 0,7:W:WF:0
led 8 0,8:W:WF:0
led 9 0,15:SW:IA:0
led 10 7,15:S:WF:0
led 11 8,15:S:WF:0
led 12 7,7:U:WF:0
led 13 8,7:U:WF:0
led 14 7,8:D:WF:0
led 15 8,8:D:WF:0
led 16 8,9::R:3
led 17 9,10::R:3
led 18 10,11::R:3
led 19 10,12::R:3
led 20 9,13::R:3
led 21 8,14::R:3
led 22 7,14::R:3
led 23 6,13::R:3
led 24 5,12::R:3
led 25 5,11::R:3
led 26 6,10::R:3
led 27 7,9::R:3
led 28 0,0:::0
led 29 0,0:::0
led 30 0,0:::0
led 31 0,0:::0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
set looptime = 1000
set emf_avoidance = OFF
set i2c_highspeed = ON
set gyro_sync = ON
set gyro_sync_denom = 1
set min_check = 1100
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rssi_ppm_invert = OFF
set rc_smoothing = OFF
set min_throttle = 1050
set max_throttle = 1850
set servo_center_pulse = 1500
set motor_pwm_rate = 400
set servo_pwm_rate = 50
set retarded_arm = OFF
set disarm_kill_switch = ON
set small_angle = 25
set fixedwing_althold_dir = 1
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set sbus_inversion = ON
set spektrum_sat_bind = 0
set telemetry_switch = OFF
set telemetry_inversion = ON
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set battery_capacity = 0
set vbat_scale = 110
set current_meter_scale = 400
set current_meter_offset = 0
set current_meter_type = ADC
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_yaw = 270
set max_angle_inclination = 500
set gyro_lpf = 188HZ
set gyro_soft_lpf = 60.000
set moron_threshold = 32
set yaw_control_direction = 1
set pid_at_min_throttle = ON
set airmode_saturation_limit = 50
set yaw_motor_direction = 1
set tri_unarmed_servo = ON
set servo_lowpass_freq = 400.000
set failsafe_delay = 10
set failsafe_off_delay = 200
set failsafe_throttle = 1000
set failsafe_procedure = 0
set acc_hardware = 0
set baro_hardware = 0
set mag_hardware = 0
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set blackbox_device = SDCARD
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# dump profile
# profile
profile 2
aux 0 0 0 1400 2100
aux 1 2 2 900 1200
aux 2 27 2 1400 2100
aux 3 20 2 1800 2100
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# servo
servo 0 1000 2000 1500 45 45 100 -1
servo 1 1000 2000 1500 45 45 100 -1
servo 2 1000 2000 1500 45 45 100 -1
servo 3 1000 2000 1500 45 45 100 -1
servo 4 1000 2000 1500 45 45 100 -1
servo 5 1000 2000 1500 45 45 100 -1
servo 6 1000 2000 1500 45 45 100 -1
servo 7 1000 2000 1500 45 45 100 -1
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 2
set yaw_deadband = 2
set default_rate_profile = 2
set gimbal_mode = NORMAL
set acc_cut_hz = 15
set accxy_deadband = 40
set accz_deadband = 40
set accz_lpf_cutoff = 5.000
set acc_unarmedcal = ON
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf = 0.600
set baro_cf_vel = 0.985
set baro_cf_alt = 0.965
set mag_declination = 0
set p_pitch = 28
set i_pitch = 30
set d_pitch = 15
set p_roll = 28
set i_roll = 30
set d_roll = 15
set p_yaw = 63
set i_yaw = 45
set d_yaw = 0
set p_pitchf = 1.400
set i_pitchf = 0.400
set d_pitchf = 0.030
set p_rollf = 1.400
set i_rollf = 0.400
set d_rollf = 0.030
set p_yawf = 3.500
set i_yawf = 0.400
set d_yawf = 0.010
set level_horizon = 3.000
set level_angle = 5.000
set sensitivity_horizon = 75
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 20
set i_level = 10
set d_level = 100
set p_vel = 120
set i_vel = 45
set d_vel = 1
set yaw_p_limit = 500
set dterm_cut_hz = 0.000
set gtune_loP_rll = 10
set gtune_loP_ptch = 10
set gtune_loP_yw = 10
set gtune_hiP_rll = 100
set gtune_hiP_ptch = 100
set gtune_hiP_yw = 100
set gtune_pwr = 0
set gtune_settle_time = 450
set gtune_average_cycles = 16
# dump rates
# rateprofile
rateprofile 2
set rc_rate = 90
set rc_expo = 65
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_rate = 70
set pitch_rate = 70
set yaw_rate = 70
set tpa_rate = 30
set tpa_breakpoint = 1500
Hi jc86,
First of all, I am not an expert tuner, but I have been watching a LOT of Joshua Bardwell's videos lately so I was happy to see no one else did this yet. I know that I can help you out. Smile
The main thing that jumped out at me was that your roll and pitch P are both quite low, especially compared to your I and D. The other thing that was obvious is that you have exactly the same values for roll and pitch, which is normal for a pure X frame with centralized weight… but then I googled your frame:
http://img.banggood.com/thumb/water/oaup...588e87.jpg
It's a pure H frame with a body that extends the whole length of the quad! So your moment of rotational inertia is way higher on pitch = PIDs will be higher, especially P. I wouldn't be surprised if ideal P for pitch is almost 2x what it is for roll, although you're probably not running an HD cam so maybe more like 1.5x.
So when you said that it felt sluggish, I immediately suspected low P, especially on pitch.
The logs bear that out:
P should be quite active, and almost oscillating on full throttle. Here's your pitch on FT:
https://www.dropbox.com/s/2ow06tyuv29wgc...0.png?dl=0
You can see that P is not very active and not even close to oscillating. Also it is lower in amplitude to D (as little as half). Its amplitude should be at least as high as D, hopefully higher.
As you'd expect, with exactly the same P value, but much less rotational inertia, roll looks a lot more active at FT:
https://www.dropbox.com/s/nnugx4py0jdh4d...0.png?dl=0
But it's still too low. D, on the other hand looks too high. But don't worry about D until you take care of P (more on that in a sec).
Here's an extreme prop wash situation where you doing a "drop 'n catch" and are literally descending straight down, on roll:
https://www.dropbox.com/s/9bq8nl0ash193b...9.png?dl=0
You are getting oscillations, which you could fix by turning P down, but to be honest this is so extreme that most well-tuned quads without KISS ESCs are going to get oscillation doing this, so don't sacrifice the tune you get 99% of the time just to cure this. It might be a clue that your roll P won't be going up too much, but not really worth worrying about yet, especially as D is so dominant that it could even be causing the oscillations in this case (D is unpredictable especially if it's too high).
The same moment of time in pitch:
https://www.dropbox.com/s/1oxyij1y3y6cos...E.png?dl=0
Now you can't even get it to oscillate in this extreme propwash, P is so low. However there's another weird thing going on: a severe pitch-up when you apply throttle (the "catch" part). This could indicate not enough I, but don't turn up I yet. I cleans up error not taken care of by P or D, and your P is so low that it is leaving a lot of garbage for I to clean up. So once you increase P, this problem should not occur in the first place.
I haven't looked at yaw, but P on pitch/roll are the two numbers you should focus on now. Do as Josh Bardwell recommends, and turn D down really low (like, 5 for pitch/roll and 0 for yaw). Then work on getting your P worked up on pitch and roll. Maybe start with P of 3.0 for roll and 4.0 for pitch. Increase roll by 0.5 each time until you can hear and see vibrations, then turn it down to 65% of that. Repeat for pitch.
Yay, my first analysis for someone else… if anyone sees a flaw here please give me feedback!
So let us know if this works. You should still have some bounce-back after flips and rolls which you will tune with D but at least it will be a lot more controllable. Then you can do D next, then I, then yaw.
Oh and by the way, please don't bake the BB graph overlay into your video. Just supply the raw video (and a start index would help, although yours was almost matched by default) . The person analyzing the log will have their own idea as to what they want to look at (and motors/gyros isn't the most useful info anyway: we need PIDs). If you notice my screenshots have your (fainter) lines behind my (solid) lines: it's my lines that I want you to look at.)
(29-Apr-2016, 02:15 PM)Relic Wrote: Hi jc86,
Thank you so much for your reply. i will certainly will try your tips Smile
Do it and post the logs and video (no overlay) again!
jc86, any luck with the tune?
Hi Relic
I am so sorry for late reply, unfortunately i have been busy with work and family lately.
I did try your tips, and it was much better, so thanks.
Today i upgraded it to betaflight 2.8.0 running blheli 14.6. (i had death roll issues with 14.5)
I am using stock pids, except that i turned P roll a little, because of the H shape.
It was something funky about it, that i cannot explain.
Just testing LOS Log file
I have this weard spikes when i dont do any changes as well Log
[Image: 34wMBeveMdKntl_AJuPi4Khz-qP_9qL9T5R4kDuk...ize_mode=3]
Hi jc86,
Glad the tips helped Smile
LOG00067:
It's hard to say much about your LOS flight because you are not flying near the edge of the envelope much. Just hovering and doing the occasional throttle punch. During those brief punches I'm not seeing any oscillation so your P can probably go up. D is looking pretty spikey already, which might be evidence of a noisy copter… is this the exact same quad or did you change some hardware?
In particular roll D is a bit out of control. When you wrote "except that i turned P roll a little, because of the H shape" you forgot to say up or down. I hope you said "down" because roll needs to be lower for an H frame. It looks like D is getting out of control on roll.
But again, we need an FPV flight like your original one to say much.
LOG00063:
A bit more to work with here but looks like you are still LOS hovering with some punchouts and rolls/flips. During those I'm not seeing any P oscillations. It doesn't seem to be following your stick movements very well: I'm seeing a lot of gyro movement sometimes when your stick is centred. It probably doesn't have enough authority (low P). I'd do the same as I said before: turn D down really low and turn P up until it obeys your sticks better, and watch/listen for oscillations in punch outs, drop and catches, and if flying FPV, hard turns.
Blackbox logs seem to have a lot of "weird spikes", some important, some not. If you see micro spikes in D on zero throttle you can ignore them according to Josh Bardwell. I'm not sure what they are but the motors can't actually react that fast. If you have a noisy copter then there is a limit to how much you can turn up D, although running the latest Betaflight will make it fly better no matter how much noise Smile
Next time, fly FPV, post the log and the raw flight video as well. Hope that helps a bit.
Thanks again Relic  Smile
After some reading i think the weird spikes on yaw gyro, actually is a general hardware problem on the MPU9250 accelerometer/gyro/compass
Finally i got to fly again yesterday. I have o-rings for vibration damping on the flight controller, that i think helped the gyro.
I have upgraded the d4r-ii to xsr (SBUS). I think that helped some on the responsiveness
Video and log files
The quad seems to fly better, but there is something wrong. For example here this huge spike happens out of nowhere
[Image: Qill5Jo4HpqbEveGI2HMz94GIcAmB_T2zIYYPy20...ize_mode=3]
During the whole flight, weird things happens  Sad
PID values are in the header of the log file.
I tried different things, turning up P and I
I'd like to take a look but you have 5 videos but 7 log files. You need to indicate which logs go with which videos. You can add a text file with this info, or even more conveniently, you can add the video file name to the log file name or vice versa.
Or just put each video/log pair in a separate folder. That's what I do. I also add a folder whose name is the log offset once I've found it:
Attached Files Thumbnail(s)
(04-Jun-2016, 05:20 AM)Relic Wrote: I'd like to take a look but you have 5 videos but 7 log files. You need to indicate which logs go with which videos. You can add a text file with this info, or even more conveniently, you can add the video file name to the log file name or vice versa.
Hi
I have done some more testing, i have followed your tips and renamed files to make it easier to combine.
Log file and video file have the same numbers. and the logfile name also include the video offset.
Example
LOG0006_+2.11.TXT
PICT0006.mp4
log file and video belongs together because of number 0006. the offset is +2.11
Files can be found here Log and video files
Hi jc86,
First of all, so sorry for the delay, I haven't forgotten about you, just got busy with "work and family" too Wink I'm looking at it now. Thanks for naming the files like that, and for doing lots of acro, way more to work with now! Smile
Will post later today.
Hi jc86,
Your logs and videos are great, thanks for packaging them that way Big Grin Also, your flying is fun to watch, so that's a bonus Smile
Do you like the way it flies now? I think you're getting there with the tune, so it's not so easy to give advice Wink that's why I took so long. In the first flight (LOG0002_+1.86) P is obviously too high on both axis, so you turn it down, and bounce back is really bad on rolls/flips so you turn it up. This all makes sense.
You then turn D up and down to find a sweet spot, also a good idea. I think your last tune (LOG0006_+2.11) needs just a bit more P on roll/pitch and a bit more D on pitch… but you already tried that on your third tune (LOG0004_+2.13) and you seemed to get oscillations.
So I don't actually know what to recommend! On your last tune (LOG0006_+2.11) you have prop wash in an extreme situation, falling straight down, but almost any tune will have that:
http://cl.ly/3z3L0M332L3h
The strange thing is that you have a weird oscillation during high throttle on all axes sometimes, and your video gets fuzzy, like here (also from LOG0006_+2.11):
http://cl.ly/1r1R070j0b3V
But usually when you are at high/maximum throttle it doesn't happen so I'm not sure it's about the tune. Check your copter for anything loose that might be vibrating at certain motor speeds (like a resonance).
You don't change I from 50 on pitch/roll for any of the tunes. If you like it where it is, don't change it. The way to test I is to do a punch out, then cut throttle, then catch, without touching the right stick at all, at different angles, so we can see how much the copter rotates. I didn't see you do that in these vids so it's hard to judge I. Do that and raise I if needed until it maintains heading. You can run I pretty high with Betaflight 2.8 because it resets I during flips/rolls automatically to prevent bounce back.
I'd say vibration is pretty low in the gyros, but you still have some, especially on yaw. One thing you can try is try Boris's recommendations for a "slightly noisy setup" at https://github.com/betaflight/betaflight/releases and set your filters to:
gyro_lowpass = 80
dterm_lowpass = 100
See if it flies smoother that way, but it might increase prop wash and reduce sharpness. You can always put it back.
Your yaw P is at the default (9.5), but you're on a 180 size quad, and too much yaw P can cause noise, so you might try reducing that to 8.5 and see it flies smoother.
Finally, if you find it too sloppy during zero throttle, I noticed your min_throttle is pretty low (1020) so try bumping it to 1050 temporarily to see if it makes the zero-throttle handling sharper, then adjust it to your taste.
Sorry I can't be of much help anymore… your PIDs are in the right neighbourhood so you need to experiment with little changes and try to find the sweet spot.
Good luck with your tune and finding out the source of that vibration!
[-] The following 1 user Likes Relic's post:
  • jc86
thanks again Relic Smile
very informative feedback.
i think my quad flies pretty good now. I think the vibrations i now see is because of bad camera mounting.
new video and log
can i get you something as thanks for your help?  Wink
  Where to put 2.4GHz ELRS RX with ceramic antenna on 5in racing quad? Luk5569 6 168 05-Mar-2024, 12:54 PM
Last Post: ph2t
  Data Zombie Quad? Green_Weedle 2 139 05-Feb-2024, 10:27 PM
  How quad building has helped my Beer brewing Rob Axel 5 224 16-Oct-2023, 01:24 AM
  Help Find my quad aerokam 16 807 10-Oct-2023, 04:52 PM
Last Post: Dak_4008
  Broke my first quad, fixed my first quad FPVme 4 293 23-May-2023, 07:11 PM
Last Post: FPVme
