After going down the BF 4.3 rabbit hole with my smaller builds (baked in ELRS anyone? ) I finally decided to try it on my daily driver, the rooster 5 inch quad that I love.
I really liked the way 4.3 (RC3 mainly) handled the smaller builds that were underpowered (1S) and the general improvements to the configurator interface. Given that now we are on RC6 I thought it would be time to try this out on a "real" quad, lol...
Here is the rooster on the operating table. Some quick specs:
My process to go from 4.2.1 to 4.3 RC6 went as follows:
Motors tab.
There is now some new functionality, very impressive actually. You can now change the motor direction without having to open Bl_heli / Bl_Heli32 configurator software. You can do this within BF configurator!
Here's what I mean:
Click on Motor direction, select manual and you get this.
Within five seconds I had all my motors spinning in the correct direction. For me this is "props out", I prefer this over props in. This is usually just a personal preference. I seemed to have the habit of collecting a lot of gunk on the fpv cam with "props in" so "props out" is for me.
This feature is awesome, makes it so easy to set up your motors.
I checked CPU, was at 45%. I changed my PID loop to "old bugger" 2K. I set DSHOT to 300. CPU came down to 35%
After checking everything and confirming the receiver and transmitter were working well together I did a quick hover in the back yard.
All good.
I decided to leave PIDs and Filter sliders at their default settings to see how it flew.
I was very happy with the performance. It feels a bit more dialed in and nimble than when I was on 4.2.1.
Here is a my maiden flight on the 4.3 RC6 build with stock PIDS and filters.
I will update the filter slider now and try again tomorrow to see how it flys.
4.3 is the best build of BF ever.
Cheers to the devs!
- Armattan Rooster 5" frame
- T-Motor PACER V2 - 2207 at 1950Kv
- Mamba F405 stack with 40A(I think?) Bl_Heli_S esc.
- Foxeer T-rex camera
- TBS vtx (cant' remember the model, lol) and TrueRC antenna
- Battery backed loud arse buzzer.
- Some rando 5" props - again can't remember, they're blue! Aggressive pitch at 4.3
- Crossfire RX
- 6S 1300 - 1400 mAh lipos
- Take screen shots of all the settings from the previous version I was running.
- Take a diff all and save it to a txt file (just in case I need to roll back)
- Remove the props, fire up a small fan (to cool the quad on the bench) and plugged in a battery.
- Using https://esc-configurator.com I updated the ESCs to Bluejay 0.16 at 24kHz - left all settings default.
- Downloaded and installed the new BF4.3 RC6 configurator.
- Plugged in the FC via USB and connected to the new configurator.
- Enter bootloader mode using the "bl" command in the CLI (who presses that button still? lol)
- Updated my FC's target (FURYF4OSD) to 4.3RC6
- Unplugged USB, unplugged battery.
- Plugged USB back in and connected to BF configurator
- Applied the custom config for this FC (happens automatically upon first connection)
- Disconnected the FC from configurator and unplugged USB to power it all down again.
- Plugged in the USB again and connected to configurator.
- Referring to the screenshots I took in step one, applied settings for the ports, RX, etc.
- Applied settings for OSD
- Applied settings on configuration tab (eg: telemetry)
- Set my rates, made sure I set the rates type to Betaflight so my old rate values were compatible.
- Set the receiver tab up correctly for CRSF and TAER1234 channel order.
- Set my modes. eg: ARM, BUZZER, ANGLE mode.
- Set up my vtx table for the TBS vtx I'm using (SmartAudio 2.1 unlocked)
- Set up the motors tab with RPM filter ON. Confirmed magnet count on the T-Motor PACERS and left it at the default since that was correct already.
Motors tab.
Here's what I mean:
All good.
Cheers to the devs!
