36x zoom camera fpv(no drone)
Hello
i have a 36 x zoom camera like this https://www.banggood.com/FPV-14-Son...s=detail-left-viewhistory__5&cur_warehouse=CN
now i need to be able to zoom with it. in this zoom video you can see how i would llike my set up to be:
Seem like he only have battery to camera and monitor and some sort of zoomcontroll. Dont really know exactly what to get for ut to work.
I gonna connect it to my fpv googles.
Hi dengro9,
the camera is controlled via a servo tester, one of those: https://www.banggood.com/search/servo-tester.html, it is simply plugged in using the rightmost servo wire.
He is using two battery packs:
one for the servo tester (because they usually work on 4-6V)
second for the monitor and camera, they need 12V. (your monitor/goggles may use different voltage)
Does that answer your question?
Best,
Konrad
(05-Jan-2018, 09:09 PM)KonradS Wrote: Hi dengro9,
Best,
Konrad
wow thanks so much , been posting two days on different forum and finally someone that knows.
Lets see if i manage to get all the correct things.
1. servo tester. dont  what multifunctional means. It obviously has to stop when i need so it doesnt just zoom in fully and i cant stop it. https://www.banggood.com/GT-Power-Alumin...rehouse=CN
2. googles: https://www.banggood.com/Eachine-EV800D-...rehouse=CN
Connecting the camera to the googles? I can see it says " video in 3.5". Guess i need some sort of adapter so i can plug the cameracables in to my googles?
Or can i put a transmitter on the camera and send directley to the googles? It says " Usage: for 1.2G/5.8G  transmitter."in the camera description.
3. Cables? Really have no idea what to use.
4. battery. Servotester says 4.8-6v. Camera says 12 v. Dont i need anything beccause its different?
Vould this battery work? it says its 11.5 v but my camera is 12 https://www.banggood.com/ZOP-Power-11_1V...rehouse=CN
1. servo tester can act as a standard knob without any "smart" functions - rotate the knob left (0-25%) for zoom out, middle (26-50%) does nothing, rotate right (51-100%) zoom in.
2. you need a 3.5mm jack, like this https://www.banggood.com/3_5mm-4-Pole-St...rehouse=CN you iwll need to solder black and yellow wires, experiment with this, I don't know how it should be soldered for your goggles.
3. I don't know what kind of wires you have on the goggles and the camera, personally I would just resolder them together.
4. yes, servo tester needs 4.8-6V, you need a power source that can deliver this voltage. It can be a separate battery or you can use a voltage regulator (with a bit of soldering).
This battery will work for the camera.
  • dengro9
I have looked at this camera a couple of times, 36x optical zoom is great, but a 700TVL sensor... Not so much, I want to know if it might be possible to replace the sensor with something else, like the new Caddx for example?
  • dengro9
After i checked videos on youtube with that 700 tvl camera i must agree that it doesnt look that good.
Therefore i wonder if its possible to buy this one and connect to the googles? its an ip camera: https://www.aliexpress.com/item/New-arri...d7d3&tpp=1
Looks extremley good for the price at least.
  New Product SpeedyBee 5.8GHz FPV Goggles Receiver Module (Analog) SnowLeopardFPV 2 1,165 14-Feb-2024, 03:24 PM
  Camera Plug Wiring segler999 5 318 30-Dec-2023, 05:17 PM
Last Post: segler999
  Camera and VTX connection best practice? husafreak 9 603 24-Dec-2023, 10:11 PM
Last Post: husafreak
  Help FPV goggles antenna boooood 2 691 04-Dec-2023, 05:38 AM
Last Post: Rob3ddd
  Best hd camera for 5 inch freestyle drone? PJKMBAKER 3 552 30-Sep-2023, 12:05 PM
