Threads: 30
Likes Received: 1,199 in 755 posts
Likes Given: 714
45 23-Jan-2019, 06:37 PM (This post was last modified: 23-Jan-2019, 06:38 PM by RENOV8R.) Interesting issue with 2 of the 3 BrainFPV Radix flight controllers I own and apparently other Radix owners have the same issue, always with ESC #3. Motor #3 behaves normally in all regards whether in BF or armed and quad will fly perfectly. BUT it doesn't matter if you go into BLHeli Configurator or BLHeli Suite, ESC #3 is not detected, only 1, 2 & 4! It's a simple fix, I just take ESC #3 signal wire and solder it to #5 motor output on the Radix and remap the resource, it's a 5 minute job and #3 now appears in BLHeli. What I'm curious about is if anyone has had this issue with a different flight controller other than the Radix. I'm just trying to figure out if this is a hardware issue with the Radix or an issue with the firmware. Anybody else had this issue?
Dude, where's my quad?
Threads: 125
Likes Given: 99
388 From my own experience with flight controllers (I don't have BrainFPV), I have never had any issue similar to yours. If others are having the same issue, I you try contacting BrainFPV. They are usually very responsive.
Threads: 265
Likes Received: 2,610 in 1,545 posts
Likes Given: 3,893
78 Seems like Brain FPV needs to fix this issue.
Threads: 11
Likes Received: 452 in 349 posts
Likes Given: 372
16 I've not encountered this. I can ask a couple flying buddies.
