18-Dec-2023, 04:12 AM
I've been enjoying the Betafpv 75 Pro on 1S, and wanted to try a 2S setup. Unfortunately the 75 pro frame has a very small AIO tray that will only fit smaller cross shaped AIOs. Not too many choices for a 2S AIO with 10A+ escs. One that looks like it would fit is the HappyModel SuperX board, unfortunately the one I ordered got lost in the mail and now it seems out of stock everywhere.
I had a 2S build with a Flywoo board that I don't fly much, and that kind of fits. The board sits down into the tray but just touches against the hoops, will have to see if that is a problem in flight. I had to resolder all the motor wires so they face in, instead of facing out. I also wanted a Walksnail whoop, and thought 2S would be better for the VTX. But after putting it together, the build seems quite heavy. In comparison the 1S 75 Pro is significantly lighter around 32g (analog) and 38g (walksanil).
Probably shave off 4-5g with a lighter canopy, thinner/shorter battery lead, and lighter ELRS antenna, but still it seems a little heavy. The Draknight 2" WS build is just a few grams heavier with a much stronger frame and slightly more prop.
Not sure I will be enjoying this. The frame I used is the glued up one I pulled off the 1S BNF. I suspect it will not hold up in a crash. Probably just run some test flights and end up moving the parts to a different build. Anyone flying a 2S 75 pro?
