250mm Tuning
So, as I stated in welcome section I built my first quad which is the ZMR250; I have been trying to get it more "locked-in" feeling so I can advance my skills in Acro/Rate mode. I was getting alot of sway and altitude change while trying to get it to hover; Today I tried some new props, and this log will be with some 6045 props... I really liked the way it flew with these versus the Gemfan 5030 I had on originally. I also tried some 5040 3 blade HQ props before these, but the log isn't uploaded yet. If you see anything that stands out to you, just let me know.. I may be missing something diagnostic wise that I need to work on. Gonna use this thread kind of like a timeline, as I learn more I will update my PIDs here or what I have found to help out others in the same situation. I am using BlackBox to log/attempt tuning.
ZMR 250 CF frame
BRS2205 2300kv
RS20A 4in1
FS-I6 + IA6B
SP Racing F3 FC
6045 KingKong Props
Tattu + Turnigy Nano-Tech 1300mah 3S (4S haven't arrived yet)
# Cleanflight / SPRACINGF3 2.0.2 Apr 22 2017 / 14:55:16 (4328b13)
name ZMR250
resource BEEPER 1 C15
resource MOTOR 1 A06
resource MOTOR 2 A07
resource MOTOR 3 A11
resource MOTOR 4 A12
resource MOTOR 5 B08
resource MOTOR 6 B09
resource MOTOR 7 A02
resource MOTOR 8 A03
resource MOTOR 9 NONE
resource MOTOR 10 NONE
resource MOTOR 11 NONE
resource MOTOR 12 NONE
resource SERVO 1 NONE
resource SERVO 2 NONE
resource SERVO 3 NONE
resource SERVO 4 NONE
resource SERVO 5 NONE
resource SERVO 6 NONE
resource SERVO 7 NONE
resource SERVO 8 NONE
resource PPM 1 A00
resource PWM 1 A00
resource PWM 2 A01
resource PWM 3 B11
resource PWM 4 B10
resource PWM 5 B04
resource PWM 6 B05
resource PWM 7 B00
resource PWM 8 B01
resource LED_STRIP 1 A08
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A14
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 NONE
resource SERIAL_TX 5 NONE
resource SERIAL_TX 6 NONE
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 B05
resource SERIAL_TX 12 B01
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A15
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 NONE
resource SERIAL_RX 5 NONE
resource SERIAL_RX 6 NONE
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 B04
resource SERIAL_RX 12 B00
mmix 0  1.000 -1.000  1.000 -1.000
mmix 1  1.000 -1.000 -1.000  1.000
mmix 2  1.000  1.000 -1.000 -1.000
mmix 3  1.000  1.000  1.000  1.000
servo 0 1000 2000 1500 100 -1
servo 1 1000 2000 1500 100 -1
servo 2 1000 2000 1500 100 -1
servo 3 1000 2000 1500 100 -1
servo 4 1000 2000 1500 100 -1
servo 5 1000 2000 1500 100 -1
servo 6 1000 2000 1500 100 -1
servo 7 1000 2000 1500 100 -1
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -CURRENT_METER
feature -OSD
feature -UNUSED
feature -TRANSPONDER
feature -AIRMODE
feature -SDCARD
feature -VTX
feature -RX_SPI
feature -SOFTSPI
feature -ESC_SENSOR
feature -ANTI_GRAVITY
feature INFLIGHT_ACC_CAL
feature RX_SERIAL
feature FAILSAFE
feature TELEMETRY
feature RSSI_ADC
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper BLACKBOX_ERASE
map AETR1234
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 2 1900 2100
aux 1 1 0 900 1200
aux 2 2 0 1300 1700
aux 3 13 1 2000 2100
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
adjrange 12 0 0 900 900 0 0
adjrange 13 0 0 900 900 0 0
adjrange 14 0 0 900 900 0 0
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
vtx 0 0 0 0 900 900
vtx 1 0 0 0 900 900
vtx 2 0 0 0 900 900
vtx 3 0 0 0 900 900
vtx 4 0 0 0 900 900
vtx 5 0 0 0 900 900
vtx 6 0 0 0 900 900
vtx 7 0 0 0 900 900
vtx 8 0 0 0 900 900
vtx 9 0 0 0 900 900
rxfail 3 a
rxfail 5 h
set align_gyro = DEFAULT
set gyro_lpf = OFF
set gyro_sync_denom = 4
set gyro_lowpass_type = PT1
set gyro_lowpass = 90
set gyro_notch1_hz = 400
set gyro_notch1_cutoff = 300
set gyro_notch2_hz = 200
set gyro_notch2_cutoff = 100
set moron_threshold = 48
set align_acc = DEFAULT
set acc_hardware = AUTO
set acc_lpf_hz = 10
set acc_trim_pitch = 0
set acc_trim_roll = 0
set align_mag = DEFAULT
set mag_hardware = NONE
set mag_declination = 0
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
set baro_hardware = NONE
set baro_tab_size = 21
set baro_noise_lpf = 600
set baro_cf_vel = 985
set baro_cf_alt = 965
set min_check = 1100
set max_check = 1900
set rssi_channel = 10
set rssi_scale = 30
set rssi_invert = OFF
set rc_interp = AUTO
set rc_interp_ch = RP
set rc_interp_int = 19
set fpv_mix_degrees = 0
set max_aux_channels = 14
set serialrx_provider = IBUS
set sbus_inversion = ON
set spektrum_sat_bind = 0
set rx_min_usec = 996
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set min_throttle = 1000
set max_throttle = 1980
set min_command = 1010
set digital_idle_value = 459
set use_unsynced_pwm = OFF
set motor_pwm_protocol = DSHOT150
set motor_pwm_rate = 480
set motor_pwm_inversion = OFF
set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 10
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = DROP
set align_board_roll = 2
set align_board_yaw = 90
set gimbal_mode = NORMAL
set bat_capacity = 1500
set vbat_warning_cell_voltage = 37
set vbat_hysteresis = 1
set current_meter = ADC
set battery_meter = ADC
set bat_detect_thresh = 55
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_scale = 111
set ibata_scale = 400
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set yaw_motors_reversed = OFF
set servo_center_pulse = 1500
set servo_pwm_rate = 50
set servo_lowpass_hz = 0
set tri_unarmed_servo = ON
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set small_angle = 25
set disarm_kill_switch = ON
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set fixedwing_althold_reversed = OFF
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 5
set yaw_deadband = 5
set pid_process_denom = 2
set tlm_switch = OFF
set tlm_inversion = ON
set tlm_halfduplex = ON
set frsky_default_lat = 0
set frsky_default_long = 0
set frsky_gps_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_int = 5
set pid_in_tlm = OFF
set ibus_report_cell_voltage = OFF
set osd_units = METRIC
set osd_rssi_alarm = 20
set osd_cap_alarm = 500
set osd_time_alarm = 10
set osd_alt_alarm = 100
set osd_vbat_pos = 2092
set osd_rssi_pos = 2088
set osd_flytimer_pos = 2081
set osd_ontimer_pos = 2102
set osd_flymode_pos = 2413
set osd_throttle_pos = 2273
set osd_vtx_channel_pos = 2425
set osd_crosshairs = 2248
set osd_horizon_pos = 2248
set osd_current_pos = 2433
set osd_mah_drawn_pos = 352
set osd_craft_name_pos = 2442
set osd_gps_speed_pos = 2266
set osd_gps_lon = 2546
set osd_gps_lat = 2514
set osd_gps_sats_pos = 2099
set osd_altitude_pos = 2295
set osd_pid_roll_pos = 2470
set osd_pid_pitch_pos = 453
set osd_pid_yaw_pos = 2535
set osd_power_pos = 2369
set osd_pidrate_profile_pos = 2393
set osd_battery_warning_pos = 2377
set osd_avg_cell_voltage_pos = 2124
set task_statistics = ON
set debug_mode = NONE
profile 1
set d_lowpass_type = BIQUAD
set d_lowpass = 100
set d_notch_hz = 260
set d_notch_cut = 160
set vbat_pid_gain = OFF
set pid_at_min_throttle = ON
set anti_gravity_thresh = 350
set anti_gravity_gain = 1000
set setpoint_relax_ratio = 100
set d_setpoint_weight = 60
set yaw_accel_limit = 100
set accel_limit = 0
set iterm_windup = 50
set yaw_lowpass = 0
set pidsum_limit = 500
set pidsum_limit_yaw = 400
set p_pitch = 58
set i_pitch = 55
set d_pitch = 40
set p_roll = 49
set i_roll = 45
set d_roll = 35
set p_yaw = 70
set i_yaw = 45
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 50
set i_level = 50
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 75
set level_sensitivity = 55
set level_limit = 55
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set rc_rate = 80
set rc_rate_yaw = 85
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 70
set pitch_srate = 70
set yaw_srate = 70
set tpa_rate = 20
set tpa_breakpoint = 1650
http://hobbylp.com/wp-content/uploads/20...111408.zip
ZMR 250CF // RS2205 2300kv // RS20A 4in1 // SP F3 // CleanFlight // FS-i6 + ia6b Ibus
Just a quick question, batteries 3s or 4s?
Oops sorry... 3S cells right now
Probably gonna have to update logs now, once I added the FPV gear onto quad the current PIDs are much worse.. I can see it oscillating in the air on hover now.. Still running those large 6045 props also. No issues with lift, but seems to be disliking the added weight.
The oscillations mainly come from D term noise, try to soft mount your FC if you can.
But to your PID values, you can try this (enter in CLI)
set d_roll = 15
set d_pitch = 20
set d_setpoint_weight = 85
save
d_setpoint_weight should make D gain more effective without introducing too much oscillations.
To be honest 6" is much harder to tune than 5"... also 4S performs much better than 3S. If you are building a new quad, 5" on 4S is the way to go.
I appreciate all your suggestions, and I will surely try that. I have seem to picked up new issue; guessing with voltage issues. I am seeing tons of "spikes" or high-freq oscillation randomly now no matter the PID. I am thinking it may be a 5V issue? Nothing has changed BUT >
Added HS1177 clone cam, Eachine VTX02, Micro MinimOSD flashed with MWOSD 1.6 for CleanFlight + hooked up to UART 2. Also a Matek Tail-Light with 8 LEDs on the 5v as well.
Tried to place the 5040 3 blade props on it (had oscillations with either prop)
Reset to default PIDs, then flew had tons of drop-out and freq spikes so I just halfed all default PIDs to eliminate that as an issue.. I am fairly sure it's going to be a 5V issue now.. You can see the freq spike in RC-Command, and you can see PID's bounce. I will be trying to modify the FC a little to make it receive less shock.
http://hobbylp.com/wp-content/uploads/20...b-last.zip
Idk... getting irritated with the FPV gear causing issues. The camera is on the 12v regulator, the rest is on the 5v.
name ZMR250
resource PPM 1 A00
resource PWM 1 A00
resource PWM 2 A01
resource PWM 3 B11
resource PWM 4 B10
resource PWM 5 B04
resource PWM 6 B05
resource PWM 7 B00
resource PWM 8 B01
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -OSD
feature -UNUSED
feature -AIRMODE
feature -SDCARD
feature -VTX
feature -RX_SPI
feature -SOFTSPI
feature -ESC_SENSOR
feature RX_SERIAL
feature FAILSAFE
feature TELEMETRY
feature RSSI_ADC
feature OSD
beeper RX_LOST
beeper DISARMING
beeper ARMING
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper READY_BEEP
beeper MULTI_BEEPS
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
map AETR1234
serial 1 1 115200 57600 0 115200
led 0 3,0::FT:0
led 1 3,1::FT:0
led 2 3,3::CBW:6
led 3 3,4::CBW:6
led 4 6,0::F:0
led 5 6,1::F:0
led 6 6,3::CB:6
led 7 6,4::CB:6
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 2 1900 2100
aux 1 1 0 950 1075
aux 2 2 0 1400 1600
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
vtx 0 0 0 0 900 900
vtx 1 0 0 0 900 900
vtx 2 0 0 0 900 900
vtx 3 0 0 0 900 900
vtx 4 0 0 0 900 900
vtx 5 0 0 0 900 900
vtx 6 0 0 0 900 900
vtx 7 0 0 0 900 900
vtx 8 0 0 0 900 900
vtx 9 0 0 0 900 900
rxfail 3 a
rxfail 5 h
set gyro_lpf = OFF
set acc_lpf_hz = 10
set acc_trim_roll = 2
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
set rssi_scale = 30
set ibatv_scale = 0
set beeper_od = OFF
set deadband = 10
set yaw_deadband = 10
profile 2
set d_lowpass = 100
set accel_limit = 0
set yaw_lowpass = 0
set p_pitch = 58
set i_pitch = 50
set d_pitch = 35
set p_roll = 44
set i_roll = 40
set d_roll = 30
set p_yaw = 70
set i_yaw = 45
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 50
set i_level = 50
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 75
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set rc_rate = 80
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 20
Switched to betaflight.. seems to have much smoother gyro and PID traces than latest CF. I am impressed.
Now we will try to eliminate any issues found with the 250mm in BF. Gotta get to the drawing board.. can't fly while at work but I can research.
you are using SBUS right? so I don't think that's a voltage issue... it's digital signal so shouldn't be affected by voltage level. Could be a faulty RX.. or something wrong with your TX..
Just a guess, do you have a spare RX or spare quad you can try see if you have the same issue to rule out a few variables?
(14-Jun-2017, 12:05 AM)Oscar Wrote: you are using SBUS right? so I don't think that's a voltage issue... it's digital signal so shouldn't be affected by voltage level. Could be a faulty RX.. or something wrong with your TX..
It's IBUS IA6B but I don't see the issue on the betaflight and I also re seated the FC on the pins.. left OSD MSP off until I get my new goggles.
Also ordered some soft mount for FC. I am not able to test on other quads this is my first build and the second is underway.
  Rate tuning B4tn 3 399 24-May-2023, 05:02 PM
Last Post: Rob3ddd
  PID Tuning Guide Oscar 5 26,987 03-May-2023, 12:06 AM
  Revival 250mm DIY project coyote_dc5 8 469 29-Oct-2020, 11:56 PM
Last Post: jorrick
  Help High Elevation Builds / Tuning blanco 1 551 21-Sep-2020, 03:26 AM
Last Post: blanco
  Pid Tuning help needed - D oscillation mld 2 1,898 21-Apr-2019, 07:20 AM
Last Post: mld
