250 going full throttle in the diirt after crash
I was flying around and i crashed my quad up side down into the dirt. When the crash happend I heard the motors making a twitching sound. Then suddenly a few seconds after the crash the quad was going full throttle in the dirt. I did not give any throttle nor do i have some kind of fail-safe in the  Devo10 transmitter or CC3D.
It was pretty dangerous and i actually cut myself trying to pull the plug. Next time iam bringing leather gloves in case it happens again so i can protect my fingers.
Do you guys have any idea what could have happend?
So in short:
  • The quad was full of dirt (no mud, so not really wet dirt)
  • I had the throttle set to 0% after the crash.
  • I turned my transmitter off after the crash.
  • The CC3D has its default fail-safe set to -1% which means it wont go to a x % throttle when it loses signal.
  • The transmitter has no fail-safe values set to any channel.
  • One of the antennas was cut in half.
I suppose the receiver just glitched out cause of the dirt. But maybe something else caused it. I hope you guys can share some experiences.
do you have airmode? my feeling tells me the failsafe didn't work... and like you said RX mul-functioned.
Never, ever turn off your transmitter while the copter is still powered.
Also, CF/BF have a 2 stage failsafe now. It's possible that you didn't set the second stage up properly.
I made a little movie about it:
I figured it was the throttle channel transmitter fail-safe not being set. I fixed it to go to 0% throttle if i turn the transmitter off.
I also relocated my xt-60 connector be in a better spot so i can just simply pull the plug if i need to.
Thanks for the replies.
make sure you bench test your failsafe.Nice job on the video
I did something like that once on landing and watched it run wide open upside down. I land goggled up in stabilized mode. The quad was trying to level it's self. I switched it to acro and it went to idle and was able to disarm.
  Solved Quad gets shaky and loud over 30% throttle. Suros 10 443 23-Nov-2022, 10:37 PM
Last Post: Suros
  Build CHALLENGE : Sub 250 – 30 M – 10K iFly4rotors 79 6,716 22-May-2022, 04:47 PM
  Throttle Range In Custom Setup DragonTheta 1 319 20-Apr-2022, 08:57 PM
Last Post: kafie1980
  GPS and motor bell fault after a crash Trial4life42 1 374 12-Apr-2022, 11:43 PM
  Repaired GepRC Cinelog35 - Crash Jello Blaze 0 762 23-Feb-2022, 06:58 PM
Last Post: Blaze
