Threads: 51
Likes Received: 150 in 106 posts
Likes Given: 256
11 I just saw reference to the A30-BT2 compatibility and a recommendation to build with A30 connectors for this reason. That being said I'm going with BT2 on all my 1S quads.
Threads: 60
Likes Received: 1,008 in 730 posts
Likes Given: 96
52 It seems if you go with BT2.0 or A30, both are cross compatible and possibly more battery options in BT2.0. Why did they recommend the A30 over the BT2.0?
However I do find it takes quite a bit more force to disconnect a BT2.0 connector, so you will need to take care especially if you're prone to pulling off battery leads.
Threads: 29
Likes Received: 405 in 305 posts
Likes Given: 322
18 I find it hilarious that while trying to monopolize the lightweight battery connector market, they just ended up with a bunch of standards that generally work together without hassle. It's probably not a bad idea to grab BT2.0 plugs and get A30 batteries as they'll be cheaper without the proprietary BT2.0 connector on them, and you can get options that aren't BetaFPV. (I like BetaFPV alright, but options>brand loyalty.)
Threads: 15
Likes Received: 76 in 49 posts
Likes Given: 151
4 It sorta sucks that there's no A30/GNB27 cross compatibility. I'm pretty invested in GNB27. I converted my open prop 1S stuff when they first came out and it really woke them up. Chargers were lacking but I have tracked down a few 6-place options. It was a cost/availability thing for me. GNB27 packs with matching leads in the box were about the same price as others and readily available on amazon. It made it very easy to try out... That reminds me. I need to look for some more GNB27 power pigtails or connectors to make some more. I want to convert some whoops... I have a few dozen batteries right now but as they die off I don't know if I'll replace them. We'll see if the A30 has taken off by then or something else has become "the standard". FWIW, I never even considered BT2.0 due to price and availability.
Threads: 117
Likes Received: 811 in 658 posts
Likes Given: 126
20 Would be great if nbd nitro nectar or any other folded cell 1s could get these .. I know they have the BT2.0.. but like you said… price
Threads: 15
Likes Given: 151
4 @BadRaven: Thank you sir. Much appreciated but I'm sure you are correct; postage would be ridiculous. lol.
