30-Jul-2016, 01:43 AM
(30-Jul-2016, 01:10 AM)sirdude Wrote: Ok folks.....put my VTX in with a "make shift (12.92mm) ant. so I could try a little FTP, but the image is out of focus?? The VTX and the RX are on the same channel and everything is on NTSC. I'm getting no interference from the motors. Have been out about 200 feet and still have a good strong signal....it's just out of focus....so much so that I can't use it to fly by. Its a Diatone 600TVL 120° Mini Camera. Anyone got any ideas on this....known problems with this camera?
You should be able to screw the lens in or out a bit for focus (unless it's glued). Usually there's a little "nubly" nut against the case that serves as a jam nut.
