Tutorial Eachine E010 Taranis, easy mod fpv - Printable Version
+--- Forum: Tutorials, Hacks and How-to (http://intofpv.com/forum-tutorials-hacks-and-how-to)
+--- Thread: Tutorial Eachine E010 Taranis, easy mod fpv (/t-eachine-e010-taranis-easy-mod-fpv)
Eachine E010 Taranis, easy mod fpv - Pimousse - 12-Jan-2017
Presentation
The Eachine E010 is a small quad principally for indoor flight. The small changes made, you will drive with your Taranis in Fpv.
The machine comes with a small radio-type "toy", a USB charger, 4 propellers reserve and a lipo battery 1s 150 mah 30c.
With the use of multi-protocol transmission module, you will be able to control your E010 with a much higher accuracy than that experienced with the original radio. With radio that is provided, the flight is entirely possible but not at all accurate.
The placement of the transmission module is very simple and is done quickly. Simply remove the back cover of your Taranis and clip it to the intended location.
Before your Taranis E010 with your well check the following settings in your radio:
  • external hf on PPM mode
  • channel range: CH1-12
  • Order of ERTA ways
mod Fpv
To take advantage of this beautiful little quad fpv, I added to it a combo cam / vtx I regained my Nano Qx fpv. I also used the original connectivity combo that I soldered on the E010 plate directly on the battery power (on the top). Of course you will find several different combo models that can adapt easily.
I completed the installation of the camera very simply with a small piece of double-sided and Colson. It is also possible to print a 3D part, for having a totally suitable support.
The installation performed is very simple, basic and very light.
The small behaves comfortably in flight and is very accurate. On the side of autonomy, with the mod fpv, I 3min30 with lipo. Which is more than correct.
video review
Conclusion
If you want to make fpv in indoor cheaply, with a small single machine that you can evolve, the E010 is for vous.L 'well known that is the equivalent inductrix fpv will cost almost 3 times the price. Personally I find this really nice machine and I'm going to recommend batteries to extend the good times
You will find here Eachine E010 Banggood and the transmission module here Banggood . If need extra batteries, upgrade and spare parts Here
Enjoy the flights everyone
RE: Eachine E010 Taranis, easy mod fpv - Akuwu - 13-Jan-2017
awesome post..thanks for taking the time bro
RE: Eachine E010 Taranis, easy mod fpv - Pimousse - 13-Jan-2017
Thx for your comment mate
