Discussion DIY Dummy Load for Discharging LiPo battery - Printable Version
+-- Forum: Hardware Discussion (http://intofpv.com/forum-hardware-discussion)
+--- Forum: LiPo Battery and Charger (http://intofpv.com/forum-lipo-battery-and-charger)
+--- Thread: Discussion DIY Dummy Load for Discharging LiPo battery (/t-diy-dummy-load-for-discharging-lipo-battery)
DIY Dummy Load for Discharging LiPo battery - thomasFPV - 07-Jan-2017
Has anyone ever built a dummy load for discharging lipo with dual channel chargers? If so, any tips and what Parts are required?
RE: DIY Dummy Load for Discharging LiPo battery - Charpu5 - 07-Jan-2017
I've built a separate constant current dummy load for this purpose. How fast you want to discharge them?
RE: DIY Dummy Load for Discharging LiPo battery - thomasFPV - 07-Jan-2017
At 1C so let's say in this case at around 10A and I'm happy. I use 1300mah and 1800mah lipos
That will be around 150-160W per channel. You won't get away without some serious cooling.
You need a load around 2ohm, that can take 200W at minimum. If you connect 10 pieces of 15ohm, 50W resistor in parallel, you'll get 1.5ohm with 500W capability on paper. Of course you'll have to use one or two fans to take the heat from the resistors.
RE: DIY Dummy Load for Discharging LiPo battery - TomP7715 - 07-Jan-2017
I use this discharger. You can connect a parallell board and discharge several batteries quite quick
http://www.banggood.com/AOK-3-in-1-150W-Discharger-Voltage-Tester-Balancer-For-Lipo-Battery-p-1051214.html?rmmds=search
RE: DIY Dummy Load for Discharging LiPo battery - Drone0fPrey - 21-Jan-2017
(07-Jan-2017, 07:37 AM)TomP7715 Wrote: I use this discharger. You can connect a parallell board and discharge several batteries quite quick
+1 for using a parallel charge/discharge board. I use mine with the iMax b6ac charger.
On a cheaper diy note. Look into using automotive lightbulbs. I have used 3057 and 194 style bulbs. With a little bit of math and some creativity you can make a set up to discharge several at once.
I use a 194 bulb to discharge my 1s 500mah packs with a mini losi plug. Just be sure you dont over discharge.
(Side note) this is also how i discharge to 0v for damaged or defective packs im going to dispose of.
