Review USV 5.8 OTG Receiver - RX USB OTG - Printable Version
+-- Forum: Hardware Discussion (http://intofpv.com/forum-hardware-discussion)
+--- Forum: FPV Gear (http://intofpv.com/forum-fpv-gear)
+--- Thread: Review USV 5.8 OTG Receiver - RX USB OTG (/t-usv-5-8-otg-receiver-rx-usb-otg)
USV 5.8 OTG Receiver - RX USB OTG - Pimousse - 04-Jan-2017
A new device to be discover, the receiver  FPV USV 5.8 OTG RECEIVER .
Remember the recent article on EasyCAP which enabled to view the video stream of our receivers on a tablet or android smartphone.
If you do not remember, I invite you to read the article >>>  here  <<<
This bundle EasyCAP + 5.8GHz receiver + cable + Lipo works fine but is not easy to take off because it's too heavy.
So I decided to look myself of a simpler solution, more embedded ...
And finally, after much research and intensive excavations in the depths of the web, I found the GRAAL!
A device that connects via USB, very small, very light, capable of receiving the 5.8GHz band, using only a single cable and without battery.
Icing on the cake, it's covers all video range, it has an OSD that displays the frequency and signal level and it has an integrated spectrum analyzer (such as CT580 I detailed before in Article here )
I hear you say ... but ... it's a joke it does not exist !!!
Well, the result of this quest, here;
I present the USV 5.8 OTG Receiver (I do not know if it has another name, I have not been able to decipher inscriptions in Chinese)
I performs the ...
unboxing
Sent in his usual bubble envelope, the USV is well protected in a metal box on which a trabsparent plastic window lets see hardware.
On the front of the box are distinguished printing with the logo and inscriptions in Chinese.
Who have not yet learned to decipher the Chinese, it is assumed that it is the mark: p
In the box we find a 5.8GHz antenna types baton, a micro usb cable to Micro USB OTG for connecting on a android device (IOS I do not know because I do not have Iceberg brand) and well protected by foam receiver which surrounds it.
A small yellow cap on the receiver antenna connector is not damaging.
Nothing more ... a little explanatory note in English would have been a must!
owner of the Tour
The receiver is about 6cm long (upper connector at the base) to about 3cm wide.
It is about 7.5 mm thick.
There's no denying it's a great compact system.
Note that the bulk of the measured thickness is caused by the antenna connector.
A weighing, including the antenna, the system weighs only 21g.
To give you an idea, it is not larger than a standard AA battery.
The connection to the antenna type RP-SMA.
OTG cable micro usb to micro usb is provided for connection to our smartphones / tablets.
Please note that to use on a PC (yes, it works too) you have to use a USB type A to Micro USB cable (such as those used everywhere and for all .. eg smartphone charger).
On PC, you can use the famous VLC (free) program to retrieve the video stream and use it in various ways (save, screenshot, ...).
Currently I have only tested under Windows 10 x64 and it works perfectly! (so I am confident that the other versions or past it also works).
Start-up
Since the receiver has no explanatory note, I have to go to grope (but not with Julie).
I connected the device to my test tablet using the micro USB cable / micro usb provided and have launched FPViewer.
Directly the device has been recognized as "USB 2.0 PC CAMERA (ARKMICRO)" and I was viewing my video feed.
CAUTION the Garden facilities OTG cable with the receiver has a way of connection!
The connector with the arrow drawn on it plugs the receiver side.
The connector with the USB symbol drawn on it plugs next smartphone / tablet.
Under the plastic layer that envelops the electronics, there is a small button that allows changing frequency.
Pressing it we change frequency by 2 MHz.
The covered frequency band extends from 5645MHz to 5945MHz or 300MHz, which is more than enough to cover the 40 standard channels.
The frequency on which it is located, and the signal level (RSSI) are displayed by OSD on the screen.
It's good but it's slow suddenly find his frequency, we know especially forward but not backward.
So I asked what would happen if I stayed down on it?
And then ... boom magic device begins to scan his entire band showing the passage spectral analysis.
Once the scan is complete, it is wedged on the signal received most powerful on the tape.
WAW! Impressive
FYI, perform a full scan of the tape takes about 18 seconds.
After a few minutes of use is noted that the heating device still okay.
Measured at 32 ° C average with a peak at 43 ° C on some places after 10 minutes of operation (measured at an ambient temperature of 20 ° C)
As it heats is probably that it consumes, with a small voltmeter / ammeter to measure USB devices was quickly made: 240mA at 5V, about 1W.
Comparison
As for the CT580 receiver, I will compare the signals received by the receiver with other receivers of different brands and sensitivities.
The images are raw: extracted from the video recording via the VLC player with the screenshot option.
The antenna is used clover-leaf type (and is not the original one), she was placed in the same way on each receiver and each receiver was placed strictly in one place.
The camera used is the Eachine MC01 AIO , she was placed on two floors up to cause actual signal attenuation.
USV 5.8 OTG device
Bundle EasyCAP + CT580 (-93dB)
Bundle + EasyCAP SkyZone RD40 (-90dB)
Eachine Goggle ONE
RF spectrum analyzer explore
Latency
We will compare the latency of the device in the same way as in the previous article on the EasyCAP.
The bundle EasyCAP / receiver 5.8GHz / tablet gave us a latency of about 100ms, it will be the reference taken for comparison during our test.
There is a latency of between 80ms and 100ms , or very close to the bundle EasyCAP + receiver.
Conclusion
This small receiver 5.8GHz OTG is really nice if we take into account that uses a single cable, no external power source other than the one taken on the smartphone or tablet.
It displays the frequency, the amount of the received signal, it can scan the entire 5.8GHz band 40 channels with a spectrum analyzer display type OSD.
Lightweight and discreet, easily held in the pocket (and you warm in the winter given the amount of heat produced)
It has it all; as sensitive as my CT580 receiver (announced at -93dB), it produces a clear, clean image the colors.
One downside: the latency !
Even if it is not a constraint for framing a shot for slow flight immersion or record a video stream, it will be for a higher speed immersion in flight or to the low-riding.
derivative use
Easier to integrate with a cardboard (also called VR mask), this little device will be fixed very easily with a simple double top or double velcro face!
The button for changing frequency or scanner thus remains easily accessible
software
Used in this test:
FPViewer
interesting links
The product tested in this article is available on a aliexpress store (this is the cheapest I've found)
There is also an alternative receiver, but more limited and imposing; I have not tested:  FPV 5.8G VMB40 40CH Wireless Video Receiver with 128 × 32 OLED Display OTG / USB / AV Connect for Android Phones PC K5BO
Review by Shunt Belua for Pimousse.be website
RE: USV 5.8 OTG Receiver - RX USB OTG - sloscotty - 04-Jan-2017
Great find and great review!! Going to be hard to resist!
Thanks Pimousse!
RE: USV 5.8 OTG Receiver - RX USB OTG - Pimousse - 04-Jan-2017
Thx mate Wink
RE: USV 5.8 OTG Receiver - RX USB OTG - GlidLov - 10-Jan-2017
hi all! i'm new on this beautiful board (congrats for that).
I have a quick question for Pimouse about this product. Can you install "QGroundControl" android APP and test with this device? This app has a small "video" windows in which you can do Picture-in-Picture with a UVC streaming device. Can you check if you can see video from this RX into that app?
Many thanks!
RE: USV 5.8 OTG Receiver - RX USB OTG - Pimousse - 10-Jan-2017
(10-Jan-2017, 12:12 PM)GlidLov Wrote: hi all! i'm new on this beautiful board (congrats for that).
Many thanks!
Hello
it's not working with the actual hardware configuration. App crash always.
Cheers
Pim
RE: USV 5.8 OTG Receiver - RX USB OTG - Dutch Drone Builder - 11-Jan-2017
Can you use this device for beginning / expirimenting in FPV?
Or is the lattency to big for FPV flying?
