Betaflight 4.5.0 Release Candidate 4 Now Available
EDIT (28th April 2024): The FINAL RELEASE of Betaflight 4.5.0 is now available. See another thread HERE for details.
The first release candidate of Betaflight 4.5 was made publicly available yesterday (Christmas Day) for anyone who wants to try it. As always, with RC releases there is an element of risk involved just like the gyro bricking issue in one of the Betaflight 4.3 RC, so if you decide to install this then just make sure you are comfortable running RC releases. Otherwise just wait until the final release.
Relevant Betaflight RC1 artefacts are linked to below. You will also need to install Betaflight Configurator 10.10.0 RC1:
EDIT (11th January 2024): Betaflight 4.5.0 RC2 and Betaflight Configurator 10.10.0 RC2 were published a few days ago. Links below now updated for the RC2 artefacts:
EDIT (18th March 2024): Betaflight 4.5.0 RC3 and Betaflight Configurator 10.10.0 RC3 were published a few days ago. Links below now updated for the RC3 artefacts:
EDIT (15th April 2024): Betaflight 4.5.0 RC4 and Betaflight Configurator 10.10.0 RC4 were published a few days ago. Links below now updated for the RC4 artefacts:
Quote:Introducing: Betaflight 4.5.0-RC1
Merry Christmas Flyers! This is our first Release Candidate for 4.5.0.
Release notes for 4.5.0 are here: https://betaflight.com/docs/wiki/release...ease-Notes
IMPORTANT: Make sure you install and use the latest version of the Betaflight Configurator (10.10.0-RC1) before updating your firmware.
Don't forget to check it out all the documentation on http://betaflight.com.
What's Changed
Features Improvements Fixes Targets Known Issues Full Changelog: 4.4.0...4.5.0-RC1
Changes to Betaflight 4.5.0-RC2 since 4.5.0-RC1
See post #3 for details.
Changes to Betaflight 4.5.0-RC3 since 4.5.0-RC2
See post #4 for details.
Changes to Betaflight 4.5.0-RC4 since 4.5.0-RC3
See post #9 for details.
[-] The following 5 users Like SnowLeopardFPV's post:
  • Suros, Luap, Eyes.fpv, lyoha, hugnosed_bat
Thumbs Up
I'm liking THE ezlanding Smile
...but you got to turn it on in CLI:
set mixer_type = EZLANDING
[-] The following 2 users Like Green_Weedle's post:
  • Luap, Eyes.fpv
Betaflight 4.5.0 RC2 and Betaflight Configurator 10.0.0-RC2 were published a few days ago. Release notes for the changes in these RC2 releases are below...
Quote:Changes to Betaflight 4.5.0-RC2 since 4.5.0-RC1
Fixes Full Changelog: 4.5.0-RC1...4.5.0-RC2
Quote:Changes to Betaflight Configurator 10.0.0-RC2 since 10.0.0-RC1
Features Improvements Fixes Full Changelog: 10.10.0-RC1...10.10.0-RC2
[-] The following 2 users Like SnowLeopardFPV's post:
  • hugnosed_bat, Eyes.fpv
Betaflight 4.5.0-RC3 and Betaflight Configurator 10.0.0-RC3 were published yesterday. Release notes for the changes in the RC3 releases are below...
Quote:Changes to Betaflight 4.5.0-RC3 since 4.5.0-RC2
Improvements
  • Do not permit MSP on softserial ports as the load on the CPU is too great by @SteveCEvans in #13303
  • Use cpu_late_10ths_percent_limit to set limit on % of late tasks in 10th of a % by @SteveCEvans in #13330
  • Log the standard deviation of gyro cycle time in SCHEDULER_DETERMINISM and TIMING_ACCURACY by @SteveCEvans in #13377
  • Make servos great again by @StNekroman in #13451
Fixes Full Changelog: 4.5.0-RC2...4.5.0-RC3
Quote:Changes to Betaflight Configurator 10.0.0-RC3 since 10.0.0-RC2
Improvements Fixes Full Changelog: 10.10.0-RC2...10.10.0-RC3
  • hugnosed_bat
(11-Jan-2024, 01:30 AM)Green_Weedle Wrote: I'm liking THE ezlanding Smile
Maybe i didnt do it right but it was kicking in while flying for me so i turned it off! it was flying like airmode was off
(22-Mar-2024, 01:04 PM)Alfonso Gordon Wrote: Maybe i didnt do it right but it was kicking in while flying for me so i turned it off! it was flying like airmode was off
With AIRMODE permanently switched on and EzLanding enabled, if you centre the pitch/roll stick and lower the throttle close to zero, Betaflight will automatically turn off AIRMODE because it thinks you are coming down to land, but if you happen to have your sticks in those positions while performing an acro manoevre in the air then the same will happen which can send the quad into freefall (AIRMODE will get switch off momentarily until you move the throttle up and/or your pitch/roll stick away from the centre). There are a couple of parameters to adjust that behaviour which Drainman speaks about in the video linked to below. Just fast forward to time position 6:59 in the video to get to that particular part.
  • Alfonso Gordon
(22-Mar-2024, 01:21 PM)SnowLeopardFPV Wrote: With AIRMODE permanently switched on and EzLanding enabled, if you centre the pitch/roll stick and lower the throttle close to zero, Betaflight will automatically turn off AIRMODE because it thinks you are coming down to land, but if you happen to have your sticks in those positions while performing an acro manoevre in the air then the same will happen which can send the quad into freefall (AIRMODE will get switch off momentarily until you move the throttle up and/or your pitch/roll stick away from the centre). There are a couple of parameters to adjust that behaviour which Drainman speaks about in the video linked to below. Just fast forward to time position 6:59 in the video to get to that particular part.
oh awesome! thanks alot! i think i'm just leaving it off for now as i disarm before touching the ground anywho. I was mainly trying it out for a few friends who are new to the hobby Smile
(22-Mar-2024, 02:13 PM)Alfonso Gordon Wrote: oh awesome! thanks alot! i think i'm just leaving it off for now as i disarm before touching the ground anywho. I was mainly trying it out for a few friends who are new to the hobby Smile
I think that it can be useful but enabled permanently can kick in when you don't expect it to and become dangerous, you should be able to decide during the flight when is active, but at this point you can simply put air mode on a switch...
Betaflight 4.5.0-RC4 and Betaflight Configurator 10.0.0-RC4 were published today. Release notes for the changes in the RC4 releases are below...
Quote:Changes to Betaflight 4.5.0-RC4 since 4.5.0-RC3
Improvements Fixes Full Changelog: 4.5.0-RC3...4.5.0-RC4
Quote:Changes to Betaflight Configurator 10.0.0-RC4 since 10.0.0-RC3
Improvements Fixes Full Changelog: 10.10.0-RC3...10.10.0-RC4
  • Eyes.fpv
  [SOLVED] betaflight 4.4 rx configuration for frsky r-xsr sim_tcr 7 2,036 31 minutes ago
  Announcement Betaflight 4.5.0 *** FINAL RELEASE *** Now Available SnowLeopardFPV 4 728 08-May-2024, 02:19 PM
Exclamation Betaflight Configurator - HELP iFly4rotors 11 612 05-May-2024, 08:09 PM
Last Post: Eyes.fpv
  Betaflight Configurator Windows - Bluetooth Connection norseman73 1 234 17-Mar-2024, 02:55 PM
Sad Mac/Betaflight no longer recognises Flight Controller after flashing Sev 1 240 02-Mar-2024, 03:31 PM
Last Post: Sev
