(2nd) Cheapest F4 AIO FC
My neverending quest to get cheap AIO FC, because somehow my crashes kill FC / MCU.
Aocoda-RC F411 AIO Flight Controller 30A
https://www.aliexpress.com/item/10050049...1802cdI7Qs
The aliexpress blackfriday coupons brought it down to about $35 CDN.
 my previous /other cheap F4 I bought/used:
BetaFPV 2-4S 12A v2. has blackbox.
https://www.aliexpress.com/item/1005004230772171.html
JHEMCU GHF405AIO-HD. 2-6S 40A. blackbox. digital plug. lots UART but pads crowded. ICM42688P!
https://www.aliexpress.com/item/1005005789277645.html
JHEMCU Ruibet 1-2S 12A. blackbox. 2 UART. ICM42688P! (mine is version with blackbox).
https://www.aliexpress.com/item/1005005103022474.html
JHEMCU GHF411AIO 3-6S 40A. blackbox. F411 so only 2 UART. weird layout. difficult if you have to repair.
https://www.aliexpress.com/item/1005005789338402.html
HAKRC F411 2-4S 20A. blackbox. 2 UART. ICM42688P. even has SCL SDA pads
https://www.aliexpress.com/item/1005004694424562.html
DarwinFPV F4 AIO. 2-3S 15A. MPU6000. no blackbox.
https://www.aliexpress.com/item/1005003782670494.html
FreeAxis F4. 25A up to 6S? looks like BMI270. 128MB blackbox.
https://www.aliexpress.com/item/1005005844783456.html
[-] The following 1 user Likes romangpro's post:
  • hugnosed_bat
cheap isnt nice, inexpensive is the goal :-)
good list of inexpensive aios. the darwin aio can use 1s either.
the reliable aio i use seems long time with many different motors was the heavy jhemcu f411 30a 3-4s for 30$ backthan, the hglrc 20x20mm 35a 3-6s and the pyrodrone 2-4s hv 12a ... all might be not available anymore.
astonishing pyrodrone aio, the fets couldnt be smaller but it holdsup seems years.
I have a friend who likes to say: something this cheap can’t be bad. But he says this about sneakers or jeans.
[-] The following 1 user Likes lyoha's post:
  • ethr
Currently the choices for me are the BetaFPV 2-3S 20A (£45) and TuneRC Poly 2-4S 20A (£50). But if the Darwin 1-3S 15A is available, they tend to sell for about £40 in the UK and that would be my go to. But I also have several of the 1S and 2S BetaFPV FC's, several of the 2-4S 12A HM Crazybee's and a couple of the Crazybee F3's. None of which i paid more than £35 for (each). In fact back last year i was buying the BFPV 12A v2 boards for £32 and the 5A for £30.
If the criteria was 30A minimum ESC, in a 25x25 format. Then I know of none that cheap. If 20x20 is included, then there are a couple that are less than £50.
Try Not, Do or Do Not
- Yoda
Things to consider:
1. UART for GPS / digital.
2. Voltage and amp rating. Personally, I always prefer 4S 20A+, otherwise cant use AIO for other quads.
3. Blackbox
4. easy pads. No close spaced rows
5. Gyro. I ve been struggling to tune quads with ICM 42688P.
More minor factors.
1. Weight
2. 10V and digital plug
3. F7 vs F405 vs F411 etc
4. 3.3V or SBUS pads (literally everybody on ELRS by now)
5. How easy to repair
  FC Flywoo AIO 12A with 400mw vtx and ELRS romangpro 8 651 08-Nov-2023, 08:10 PM
  jhemcu 1-2s elrs aio hugnosed_bat 8 1,415 26-Dec-2021, 08:08 PM
Last Post: romangpro
  FC JHEMCU H743 AIO 40A romangpro 9 1,161 06-Sep-2021, 12:16 PM
Last Post: iFly4rotors
  FC Happymodel CrazyF4 ELRS AIO 5in1 FC V-22 30 4,915 11-Jun-2021, 12:00 AM
Last Post: V-22
  FC New 26x26 AIO FC from iFlight iFly4rotors 19 5,813 24-Mar-2021, 01:26 PM
